Best way to spray clear gloss
    July 2014
Posted by teejay on Sunday, November 16, 2014 7:23 PM
I am putting gloss clear coat on an car body and if I lightly spray it, it will dry with a mist look and not flatten but if I spray it more to removed the mist look some of the coat will over flow on the bottom of the car. What's the best way to do it?
Posted by Tojo72 on Sunday, November 16, 2014 7:51 PM
Light coats always work best.You just need to practice with the right mix,psi,and distance away till you get it right.
    March 2010
Posted by Nathan T on Sunday, November 16, 2014 7:55 PM
Actually, I find light coats don't work. You need to use a larger needle, nozzle size and spray it on heavy, or just before it starts to run. Remember to use at least 50% overlap and hold the airbrush farther away from the surface than you normally do.
    July 2014
Posted by teejay on Sunday, November 16, 2014 9:02 PM
I forgot to mentioned that I used rattle can to do my gloss coat
Posted by Don Stauffer on Monday, November 17, 2014 9:04 AM
I find a good thick coat works but I put it on by doing several light coats in immediate succession.  But there is a point at which it gets too thick and will run.  Like most skills in modeling, practice helps.  Paint a hunk of something and then practice glosscoating till you find the optimum thickness.
    July 2014
Posted by teejay on Thursday, November 20, 2014 9:42 AM
Do you spray your clear coat from top to bottom or bottom to top?
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, November 20, 2014 7:11 PM
Depends on the subject. On autos, I spray each side at a time. Aircrafts, I start with the undersides first (top side, front and back) then the topside each side at a time. All in light coats using rattle can clearcoats.
    February 2007
Posted by mitsdude on Friday, November 21, 2014 12:16 AM
Check the last few vids from Trekworks on youtube.
One of the guys on there was showing how to do this exact thing.
    January 2014
Posted by Silver on Tuesday, January 20, 2015 11:17 PM
Hold about 1/12 inch from the surface at 19 to 25 psi.Thin about 65%.
Posted by Texgunner on Wednesday, January 21, 2015 8:24 AM
Silver
Whoa! 1/12" in mighty close to your work, eh?  Watch out for runs...Big Smile
"All you mugs need to get busy building, and post pics!"
    January 2014
Posted by Silver on Wednesday, January 21, 2015 8:35 AM
You will not have any runs if you control your psi.Your other choice is to enjoy dust spoil.
