Hey guys,
Haven't seen anything in a search turn up that is relatively current info on this, but I'm wondering what the best method is for airbrushing Testors Glosscote. I have the ratio down fine, I just need to know if misting light coats is ok, or do you need to let a sort of 'pool' build up a little bit as you sweep the airbrush back and forth? I don't typically use Glosscote for a glossy finish--I just like it because it's a nice lacquer layer to do acrylic weathering over, and it dries quickly. FWIW, my bottle of glosscote is around 10 yrs old. I know there was some question on whether the formulation changed.
So, mist it? Or go heavier? Just doing a single coat.
Thanks!
Chris
