Painting camo again
    August 2012
Painting camo again
Posted by JMorgan on Sunday, January 25, 2015 12:20 AM
I am using a Paasche Talon with a .38 mm tip and keep getting over spray around where the camo goes. It seems higher pressure helps to eliminate it but that also pools the paint and it develops runs. Spraying at an angle helps as well but you can't easily do that for the whole perimeter of the camo splotch. Do I need a new smaller tip or what?
    August 2009
Posted by denstore on Sunday, January 25, 2015 6:29 AM
Thinner paint and lower pressure. Build up the paint on several passes.
Better an airbrush in the hand, than ten in the car....Stick out tongue
    August 2012
Posted by AndrewW on Sunday, January 25, 2015 7:18 AM
It sounds like your demand for paint is too high.  What about masks to stop the overspray?
Life is hard, it's even harder when you're stupid - John Wayne.
    August 2012
Posted by JMorgan on Sunday, January 25, 2015 9:38 AM
I use a 1:1 mixture at about 5 PSI.
    August 2012
Masks are the easy way out.
