Paint primer options?
    September 2014
Posted by rooster513 on Thursday, February 19, 2015 10:09 AM
Can anybody recommend a good "hardware store" primer for airplanes? Looking for something that will cover several kits (1/48 usually) without having to spend an arm and a legSmile Or am I much better off going with a Tamiya, Model Master or some other name brand? I use Tamiya acrylics.
-Andy
-Andy
    November 2008
Posted by iraqiwildman on Thursday, February 19, 2015 4:25 PM
I did not like using hardware store primer. It seems like it is too thick and had to use in a spray can. I really like AK Interactive, Vallejo or Mr. Surfacer 1200. The first two are acrylics and Mr. Surfacer is solvent based, so it really sticks well.
Tim Wilding
    December 2011
Posted by Chrisk-k on Thursday, February 19, 2015 4:54 PM
Solvent-based modeling primers work much better than acrylic primers.  They are not expensive at all.  A Tamiya bottle sells for less than $4 and is good for priming more than 10 kits.  Compared to the price of a kit, Tamiya or Mr Surface primer is a bargain.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    September 2014
Posted by rooster513 on Friday, February 20, 2015 6:23 AM
Thanks guys! I'll take a look into Mr. Surfacer and give it a try. Thanks for the feedback!
-Andy
Posted by Don Stauffer on Friday, February 20, 2015 9:30 AM
I use Krylon primer- get it at either Walmart (cheapest normal price) or at Michaels crafts when I have one of their 40% off coupons.  Good for plastic or metal.
    August 2010
Posted by flyinyak on Saturday, February 21, 2015 10:25 PM
I'm a big fan of Tamiya primer - never had an issue with it and it lays down a great base. Pretty foolproof. One thing I've been experimenting with now is using Tamiya paint from the bottle (usually black) thinned with their lacquer thinner as a primer. I needed a primer to go under Vallejo Model Air and did not want to go through the trouble of using the rattle can primer. Works great and dries fast - seems to bond quite well.
    December 2012
Posted by Thwaite on Sunday, February 22, 2015 7:00 PM
I'm with flyinyak. Am very please with Tamiya Grey and white primer. Works well and preserves surface detail. Almost seems to enhance detail in some way?.
On the bench: 1/32 trumpeter Douglass Dauntless ,1/48 tamiya Lancaster
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, February 22, 2015 9:50 PM
I use Rustoleum grey primer
    September 2014
Posted by rooster513 on Monday, February 23, 2015 7:00 AM
Thanks for the feedback guys! Well the temp finally got above 25-30deg here in upstate NY (for one day at least)! Due to the fact that the closest hobby shop is about an hour away I decided to run to Wal-Mart and give the Krylon a go as Don suggested. I'm actually very happy with how it went on. Smooth and doesn't seem to be too thick, though we'll see when it comes wash time if the panel lines are full. Unfortunately the deep freeze is back so I don't know when I'll get to put on color. I'm itching to paint though so I may just do it and apologize to the wife and dog for the smellWink
-Andy
-Andy
    January 2014
Posted by Silver on Saturday, February 28, 2015 10:50 PM
Tamiya prer
    January 2014
Posted by Silver on Saturday, February 28, 2015 10:51 PM
Tamiya primer.
Posted by wjbwjb29 on Monday, March 2, 2015 2:27 PM
Ace primer
On the Bench:   Trumperter Tsesarevich on deck Glencoe USS Oregon
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, March 3, 2015 2:53 PM
I forgot to mention when I use Rustoleum primer, I spray lightly between coats.
Posted by Bish on Tuesday, March 3, 2015 3:15 PM
I only started using primer last year, an di started with Mr Surfacer 1200. But I read some good comments about Alclad primer so I tried some and love it. Its just as good as Mr Surfacer and you get 3 times the amount for the same price. It also comes in grey white and black.
    September 2014
Posted by rooster513 on Tuesday, March 3, 2015 3:31 PM
Bish, how does the Alclad work with different paints? I use Tamiya acrylics mostly, have you ran into any issues with anything you've tried?
-Andy
Posted by Bish on Tuesday, March 3, 2015 3:46 PM
No, I mainly use enamels, but on my last AFV I used Tamiya acrylics and had no issues. And last year I use it under Vallejo Model Air, again, no issues. Its a lacquer and just like there NMF finish's you can put enamel and Acrylic over it. Its a lovely finish and doesn't need any thinning.
I have also just switched to the Alclad range of varnish and am becoming rather a fan of there stuff.
    January 2013
Posted by jibber on Tuesday, March 3, 2015 4:48 PM
Ive tried several and the best I've found is by Army Painter and it comes in different colors. Its usually used with gaming pieces but its the best and easiest to me.
