Completely new to airbrushing, advice on next steps to take
    February 2015
Posted by DangerIsGo on Monday, February 23, 2015 11:37 AM
I did models when I was younger, and you know how it goes...I never really appreciated it and just did it as fast as I could.  Didn't even let the glue dry...literally!  I recently picked up an F-22 model from the store and wanted to get back into it but this time, with much more appreciation and dedication.  I saw that I needed X paints so I went to amazon and got the paints that the manual said.  These were them:
http://www.amazon.com/gp/product/B0035LQPTQ
All of that brand/size.  Well, as I went along, I found that the lighter the paint, the more difficult it was to get a nice coat.  White was a real pain.  I'd have to apply 10-20 coats and even then, it was too blotchy.  So I was looking at airbrushing and it seems as if its a much better option for the less detailing work but I have no idea where to start. Ideally, Id like to stay below the $100 range.  Questions I have:
1) I assume I need a compressor, right?  Are they loud?  I'm in an apartment so noise is an issue.
2) Paint colors.  Do I have to mix my own colors to get the color I need or do they come 'pre-packaged' like the testors?  e.g. Aluminum, Light Ghost Grey, etc....  Can I use my current paints or do I need a special kind?
3) Will they provide a better look and a more consistent look than paint?  Id assume so but just want to check.
I know I have more questions but I honestly can't think of them right now.  Thanks!
Posted by Texgunner on Tuesday, February 24, 2015 8:41 AM
You might look into CO2 for an "air" source; no moisture in the line ever and no noise at all.  I like my set-up.  Just a thought that might work for you.
Gary
"All you mugs need to get busy building, and post pics!"
Posted by Don Stauffer on Tuesday, February 24, 2015 9:15 AM
Most general purpose compressors are loud (but less expensive).  Some compressors made for airbrushing are quite quiet, but more expensive.  You get what you pay for.
An intermediate cost solution is to buy a cheap but noisy compressor, and a portable air tank.  Fill the tank in the garage with the compressor, take filled tank down to workshop. I know a couple of folks who use this solution.  This requires a small regulator on tank, but regulators are not too expensive.
    November 2014
Posted by BLACKSMITHN on Tuesday, February 24, 2015 9:47 AM
I picked up a very quiet no-name airbrush compressor with tank, from eBay for $89 with free shipping. It's WAY, WAY, WAY quieter than my Porter Cable general purpose compressor that I had been using, which basically sounds like a lawn mower. I've had it for about 6 months, use it every weekend, and have experienced zero problems with it. You can also find some decent Chinese made airbrushes in the $20 to $30 range. They're not exactly Iwatas, but they'll serve until you can afford an upgrade.
    February 2015
Posted by Bick on Tuesday, February 24, 2015 5:11 PM
I think you can get into airbrushing for your $100. Here's a couple on Ebay:
www.ebay.com/.../190749076540
or better, this:
www.ebay.com/.../191210499970
or go to Harbor Freight with a 20% coupon and buy their compressor and deluxe airbrush total ~$100
None are top-o-the line but do work and should last quite a while. I have and used the HF ones for over 3 years without problems but have since gone to other AB's and a tank compressor. I think the ones listed above probably come from the same factory as the HF ones. Just some thoughts.
