Airbrush problem & solution
Posted by jan_nienaber on Wednesday, February 25, 2015 3:07 AM
Good evening all!
Just wanted to share my experience recently with a problem I had with one of my airbrushes (I have a "thing" for airbrushes - I buy airbrushes like my wife buy shoes. Just can't walk past the airbrush counter at the hobby store).
I bought an Iwata Neo CN when it was just released here in Canada - about 2 years ago or so (cheap, too good a deal to pass by). Notwithstanding all the horror stories one hear about the Neo series, mine worked fantastically well - so much so that my other Iwatas were used less and less. Until a couple of weeks ago....
I was working on laying down the camo pattern on a PCM Hawker Tempest, airbrush working perfectly all afternoon, as always. Next day I want to continue, and for the first time I was having issues - spitting, paint starts then stops, bubbles forming in the cup.... Take airbrush apart, and clean it (again) - still problems. I Googled around and from Don's Airbrush Tips a suggestion was that the tip ("nozzle" as Iwata calls it) may be cracked. So I examine the tip, see nothing wrong, take out a magnifying glass, still don't see anything wrong...
Eventually remember that I have access to a microscope (optical) and decided to try that. Lo and behold, under 200X magnification there is a crack visible in the tip, so big that it looks like part of the grand canyon. I was pretty baffled that I could not see a crack that size with at least a magnifying glass, try again using the naked eye & magnifying glass - the tip/nozzle looks perfectly fine. Put it back under the microscope - Yup, the crack is STILL there!
I ordered a new tip from Coast Airbrush and they delivered it three days later, I installed it and the airbrush is back to normal again. I have no idea how the nozzle cracked, suffice to say that I will be SUPER careful in future - no bumps etc if I can help it....
So if you are having inexplicable issues with your airbrush - and especially if you notice bubbles forming in the cup - it may be time for a new tip (or "nozzle" if you like).
    October 2008
Posted by Don Wheeler on Wednesday, February 25, 2015 10:52 AM
Good tip!  The Neo nozzle is very fragile, and the space around it for air flow is very small.  Be very careful when you install the needle not to push too hard.  A spare nozzle and needle are nice things to have on hand.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    May 2013
Posted by Greg on Wednesday, February 25, 2015 11:01 AM
I've often wondered how much magnification might be required to expose a needle tip crack.
Thank you for an eye-opening and informative post. I might just take my needles into the office for microscopic inspection just because.
Posted by Texgunner on Wednesday, February 25, 2015 11:10 AM
I've found that a jeweler's loupe is pretty handy to have around.Smile
"All you mugs need to get busy building, and post pics!"
    May 2013
Posted by Greg on Wednesday, February 25, 2015 12:24 PM
Texgunner
Which adds a stage II to my experiment. Compare what I can see with a microscope to a jeweler loupe.
Good idea, Tex. I have one at work, never thought about having one at home for the hobby. Doh!
Posted by jan_nienaber on Thursday, February 26, 2015 2:45 AM
Thank you all - and thank you Don, your airbrush tips saved the day for me. What worries me now is that I "retired" my first airbrush (a Badger 100 side-feed airbrush that I bought in 1976) because it was acting up and doing more or less the same thing. My assumption was that it was just plain worn out... I will take it apart and examine it under the microscope as well.
On a side note, quite interesting to compare the 40-year old Badger with the current model 100 - you'd think it would be the same, but it is actually different internally. More or less the same parts though.
Sincerely
Jan N. in BC, Canada
