Are all thinners equally "thin"?
    May 2006
Posted by CarnivourousDonut on Thursday, March 5, 2015 7:14 PM
I'm trying my hand at pin washes, and while I use Tamiya Acrylics, and Tamiya thinner, I'm not getting the "thinness" I think I should be getting (in other words, the wash isn't running off the brush like I've read it should)
I've been using a 1:10 (paint/thinner) ratio as suggested elsewhere. What am I missing/doing wrong?
Let's rattle the cage, crack the machine. Let 'em know who you are, shine to be seen.
    March 2010
Posted by Nathan T on Thursday, March 5, 2015 7:18 PM
Well, you can try more thinner, but Tamiya acrylics are terrible to use for washes though.
    May 2006
Posted by CarnivourousDonut on Friday, March 6, 2015 4:14 AM
I did not know this, suggestions instead?
Posted by Tojo72 on Friday, March 6, 2015 6:48 AM
Enamels and oils work best for washes.The ratio is about 90-10
    March 2010
Posted by Nathan T on Friday, March 6, 2015 7:44 AM
Also try craft tube acrylics, such as Grumbacher. Mix them up with water. Tamiya acrylics dry way too fast to be used as a wash. It will work, but you'll be frustrated all the way.
    December 2011
Posted by Chrisk-k on Friday, March 6, 2015 12:40 PM
CarnivourousDonut
I suggest you use oil washes with a ratio of 1:20. Oil washes are infinitely easier to use than acrylic washes.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    May 2006
Posted by CarnivourousDonut on Friday, March 6, 2015 3:01 PM
Thank you for the suggestions. So some oil tube paint, and Tamiya thinner will suffice?
    December 2011
Posted by Chrisk-k on Friday, March 6, 2015 3:46 PM
You need a thinner for oil paints such as Mona Lisa Odorless Thinner.
    March 2010
Posted by Nathan T on Friday, March 6, 2015 4:26 PM
Don't use Tamiya's thinner for washes! It will take off any underlying paint.
Posted by Bish on Friday, March 6, 2015 4:41 PM
Get a good quality oil paint as well. Windsor and newton is a popular brand and very good for oils. To thin you need something like white spirits, what I believe in America is called mineral spirits.
Are you using Acrylic or enamel paints. If the latter, you will need to protect that with a clear acrylic coat.
