Compressor/airbrush question(s)
    March 2015
Posted by harp.ta on Friday, March 6, 2015 11:40 PM
So I've been using a Paasche H and D500SR compressor for the last year or so and earlier tonight the compressor made a fairly loud "pop" and continued running - more quietly, and, most importantly, with no air pressure.  I've contacted customer service at Paasche and am awaiting a response.  To me, a year seems like an absurdly short amount of time for a compressor to burn out in (am I being ridiculous?) and so if the response from Paasche isn't to my liking, I'm thinking about using this unfortunate turn of events as an excuse for switching to Tamiya equipment or another brand of compressor that will work with my Paasche H.  I'm wondering if anyone has had a similar experience with that compressor and can maybe verify whether its worth the extra money to switch to Tamiya compressor and AB?  Anyone know how the Tamiya AB's stack up in terms of reliability/ease of maintenance/performance?  I mostly do 48th scale air and 35th scale armor, with an occasional 350th scale ship mixed in as well; I would probably be buying the HG single action 74519 (and eventually the superfine double action 74514 a little bit later).
On the Bench:
  • Tamiya 1/48 A-1J Skyraider (USAF)
  • Tamiya 1/48 He-219 A-7
  • Tamiya 1/48 P-47M
In the Fridge:
  • Modern Times Brewing Blazing World
  • Lawson's Finest Liquids Sip of Sunshine
  • Half Acre Gone Away IPA
"Why do they lock gas station restrooms?  Are they afraid someone might clean them?"
- George Carlin
Posted by Texgunner on Sunday, March 8, 2015 10:03 AM
Switch to CO2 and forget about your compressor woes.  No noise, no moisture.Smile
"All you mugs need to get busy building, and post pics!"
    March 2013
Posted by patrick206 on Sunday, March 8, 2015 3:02 PM
Harp - I have no experience with the Paasche compressor, I used a Badger diaphragm model for decades with no problems, but now with hearing aids too loud so I went to piston type. I used Paasche airbrushes for many years, parts quality went down in past few years, went to all Badger and am sold on them.
For my compressor I use a California Airtools, model 1610A. Twin cylinder, onboard tank, zero to full pressure takes just over one minute, extremely quiet. When at full pressure I switch it off, then I can spray for 10-15 minutes before I need to switch it back on. My wife, (who often hears TOO well,) can't hear it in the next room. Home Depot carries it, $150 delivered to home. I recommend it highly.
Just my personal input: There are many fine airbrushes out there, I've tried several of them, but overall I find my most often used are all Badger's, the 200 single action siphon, 200G single action gravity cup, 100G double action gravity cup and 155 double action siphon, with super fine detail optional parts.
I find the Badger airbrush line to be of dependable quality and function, the affordable prices make them a good value. If you watch for sales at Chicago Airbrush or TCP Global, (I have bought from them both,) you can pick one up quite reasonably. But if your Paasche H works well for you, it is quite a workhorse and does a good job.
I understand the Tamiya airbrushes are made for Tamiya, by a company that produces them for a major airbrush brand. I think they are kind of pricey, but should be of good quality.
Have you visited Don's Airbrush website yet? Just Google it, you'll find a wealth of info about most everything related to airbrushing and associated equipment. Well worth a look through it. Good luck in your search.
Patrick
    January 2006
Posted by Paul Budzik on Sunday, March 8, 2015 7:27 PM
I just put these up ... they might be helpful
Paul
    June 2013
Posted by rjhansen26 on Tuesday, March 10, 2015 4:47 PM
I googled your compressor, it looks like a pretty simple setup. My first thought is that the diaphragm ruptured in the pressure regulator. Can you remove the pressure regulator and see if there is air coming out of the compressor?
Roger
Roger
"Life is short..........Always eat dessert first!"
    October 2007
Posted by Milairjunkie on Tuesday, March 10, 2015 6:16 PM
I believe that the D500SR is a branded Chinese compressor..... While not specifically the D500SR I'm aware of a few of these that have the con-rod come detached from the motor shaft either due to a loosened fitting bolt/nut or broken con-rod. It usually causes what you describe - a loud noise as the con-rod comes adrift & then very quiet running when the motor continues to run without any load.
Removing the four Philips screws from the front cover reveals the motor shaft / con-rod assembly & it should be pretty easy to tell if that's the problem.
A failed non return valve in the head, a failed seal or a failed flapper valve would all cause little / no pressure output, but it doesn't sound like any of these.
The next significant step up in quality from the D500SR would most likely be a Sparmax.
    March 2015
Posted by harp.ta on Thursday, March 12, 2015 9:52 PM
Thanks for all the responses guys, they all helped quite a bit.  Paasche customer service told me to mail in the compressor and they're going to warranty service it even though its a month past the 12 month point.  As lousy as it is for it to wear out in a year, the customer service has been quite impressive so far.
On the Bench:
  • Tamiya 1/48 P-47M
In the Fridge:
- George Carlin
