Any recommendations for a reason why I can't seem to get the glosscote to lay perfectly level. AB at 15-20 psi thinning with lacquer thinner about 50-50.
It's shiny just not as smooth as a thought
Three coats also
Sounds like orange peel. Usually happens when it's drying before hitting the surface. Are you getting a good, wet coat down?
I thought so. Maybe I should lower the psi a little
