cleaning tamiya acrylic from my airbrush
    March 2015
Posted by Alientipod1000 on Monday, March 23, 2015 7:13 AM
hello modelers! I have a expo super detail gravity feed airbrush so is this tamiya paint retarder good to clean acrylic from my airbrush.
    October 2010
Posted by hypertex on Monday, March 23, 2015 9:32 AM
Retarder is not a cleaner--it's a substance keeps the paint wet longer. I clean Tamiya acrylics with Windex or lacquer thinner. You could probably use alcohol, too. Check your Airbrush paperwork to see what they recommend.
Posted by Tojo72 on Monday, March 23, 2015 11:38 AM
You can use iso alcohol 90 or just plain water to clean Tamiya from an airbrush.
    December 2011
Posted by Chrisk-k on Monday, March 23, 2015 11:51 AM
I use 91% IPA to clean my 3 Iwata ABs after spraying Tamiya.  I've never had a problem.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    October 2007
Posted by pordoi on Monday, March 23, 2015 3:40 PM
You can also add a little Windex with ammonia to the 91% isopropanol.  Works very well.
Don
    October 2006
Posted by JunJon on Monday, March 23, 2015 7:38 PM
Am I the only one here who clean an AB with a hardware lacquer thinner?
Spraying and cleaning I still have to wear this...
www.ebay.co.uk/.../261732142129
    January 2005
Posted by Watchmann on Monday, March 23, 2015 8:49 PM
I spray a cup of distilled water to finish up, just to remove any left over chemicals.
    March 2011
Posted by Taps88 on Monday, March 23, 2015 10:14 PM
I use Isopropyl Alcohol
Eric / Formally known as Erock68
On the Bench:
Academy: 1/72 B17 Memphis Bell
Tamiya: 1/35 Panther G
Dragon: 1/35 Platformwagen SSy
    May 2011
Posted by Real G on Tuesday, March 24, 2015 1:23 AM
I also use hardware lacquer thinner to clean out Tamiya acrylic from my airbrush. Works a charm.
“Ya ya ya, unicorn papoi!”
    February 2015
Posted by Bick on Tuesday, March 24, 2015 7:44 AM
If the acrylic paint has dried in the airbrush, I, too, use lacquer thinner or acetone but make sure you AB has Teflon seals and not rubber O rings.
