Okay, I have a good fan that I just wired - it works! yay! - and I have a good ducting and vent system in place. BUT......
I have a wide and moderately deep plastic tote that I was going to use in a cross-draft configuration. However, I did a crazy thing last night and set the tote on top of the fan, in a down-draft config, and it just seems to be a better fit. I even picked up another tote, this one much deeper but not as wide, that would probably work better as a hood. Both present some unique construction challenges. The main difference between the two is the original config sits on the table top, while the down-draft config sits much higher off the table (I might have to get a taller chair or stool if I go with that)
Any suggestions are appreciated and could prove to be useful
