You could also use your Lacquer and Enamel clears over Tamiya without a problem if you allow enough time to cure.You could also use Future as you state.
You could also use Tamiya X-22 Gloss clear
I use Future or Tamiya gloss clear.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
There are a number of brands of spray paint that have clear acrylic gloss, as well as acrylic clear matt and semi-gloss. Krylon is one brand with acrylic clears.
