Varnish on top of every layer
    November 2014
Posted by sherbir on Thursday, April 9, 2015 3:30 PM
So I am repainting the camo scheme on my B-52 model. I have base coated the entire model with light dust/mud brown color and now I will add two tones of green camo over this base color. I want to know which would be a better idea:
1. Cover the base coat with varnish - paint the first tone of green - varnish again - paint the second tone of green - varnish again
OR
2.Base coat - first green tone - second green tone - varnish in the end
Regards,
Sherbir
    October 2007
Posted by Milairjunkie on Thursday, April 9, 2015 4:20 PM
2)
As long as you leave enough time for the paint to dry between colours, mask carefully & appreciate that (acrylics) can be quite delicate without a clear coat there isn't any real need to clear between colours. I've done plenty of camo birds & have only ever put a clear down as a final coat.
    March 2010
Posted by Nathan T on Thursday, April 9, 2015 4:22 PM
sherbir
OR
No need for any of that. You'd have one heck of a paint layer. It will do nothing for you. Paint your camo, then gloss varnish for decals if your paint went on a bit rough, then seal the decals with a gloss or semi gloss.
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, April 9, 2015 9:49 PM
Makes no sense in what you're trying to achieve by adding a coat of varnish between colors. A total waste of time really. Nathan is right though.
Posted by Don Stauffer on Friday, April 10, 2015 8:56 AM
I would not use varnish- an acrylic or lacquer is handier.  Also, I would only use it for decal areas or as a final gloss coat to get a gloss finish.
Posted by Tojo72 on Friday, April 10, 2015 9:47 AM
You don't need it between coats,just a clear coat at the end to protect from possible weathering that you might be doing.
