Eduard canopy masks?
    February 2006
Posted by Wilbur Wright on Thursday, April 23, 2015 6:53 PM
I have the Revell A400 Grizzly  in 1/72 scale coming up.
Have any of you used the pre-cut Eduard canopy masks, and do they work well?
I've never used them before in all the years.
Thanks for opinions
    March 2010
Posted by Nathan T on Friday, April 24, 2015 2:03 PM
They work perfect. Buy as many sets as you can and don't look back.
Posted by Tojo72 on Friday, April 24, 2015 3:34 PM
Yes they work well with patience and practice,not automatic for sure.
    February 2006
Posted by Wilbur Wright on Friday, April 24, 2015 6:12 PM
Its going to cost me around $16 bucks delivered  for this set, which is not cheap,  so I'm hoping it would be more automatic than the tedium of cutting custom masks at this scale, and provide a better result.
Also I'm presuming you can burnish the masks with a toothpick without destroying them? Then get them off without scratching the canopy.
Thanks for the input.
    March 2013
Posted by patrick206 on Sunday, April 26, 2015 4:59 PM
Yes, they do work quite well, a bit of exceptional care is needed when placing to ensure accurate positioning, but the practice becomes intuitive very quickly. I liku'm.
But, I also am used to just using thinly sliced bits of tape, trimmed to size, good way to pass the time in the evening, (beats TV,) and is a lot less expensive with same results, even more satisfaction. Montex works well for me too.
Patrick
    March 2010
Posted by Nathan T on Sunday, April 26, 2015 5:01 PM
They are well worth any price if you ask me. Burnish down with a toothpick. They come off very easy and leave no residue.
    April 2009
Posted by Cadet Chuck on Sunday, April 26, 2015 8:08 PM
Another tip- after you burnish them in place, lightly brush a line of future / pledge / clear acrylic along all the edges, to prevent any paint seepage under the masks.  Works very well.
    February 2006
Posted by Wilbur Wright on Wednesday, April 29, 2015 1:02 PM
Thanks Guys,
I usually will future a canopy before masking either because the mold line has been sanded out or in the case of the A400 just to get a more realistic glass-like look.
So once I set the Eduard masks after doing this.....If I hand paint a small line of future to seal the masks (sounds like good idea).......won't that make removing them very difficult if not near impossible?
    March 2010
Posted by Nathan T on Wednesday, April 29, 2015 5:07 PM
Wilbur Wright
Thanks Guys,
You know, to each his own, but if you ask me, don't seal the mask with future. It does nothing for you, except make a mess. No need to seal the mask edges down. Just burnish them down well, then lightly airbrush the color on.
    March 2013
Posted by patrick206 on Thursday, April 30, 2015 1:25 PM
I second Nathan's post, the masks make for a very tight and well sealed edge if burnished down. I tried the Pledge bead, it MOSTLY worked as intended, but in places the pledge stayed on the paint and pulled away from the tape. I had to carefully slice along where the edge was, to cut away the remaining Pledge overlay. It turned out OK, but not great, looked a bit rough up close.
Maybe I didn't do it as well as others, they seem to have good results with the pledge bead, but I have yet to have a mask leak anything under the edge.
Patrick
