Opposite to Pledge, anyone?
    April 2012
Posted by pianodog on Wednesday, April 29, 2015 8:20 AM
Hello everyone,
Any one knows a good flat base finish for airbrush to be use with Mr. Color or Tamiya (sometimes). As always your tips will be appreciated.
Luis
On The Bench:
Hasegawa Egg Plane F14 Tomcat
Moebius Penguin
Moebius Robin
Meng WWT-001 Tiger I
Meng WWT-002 Sherman
    December 2011
Posted by Chrisk-k on Wednesday, April 29, 2015 3:19 PM
I assume you are asking for a matte varnish.  I've used Tamiya XF-86 flat clear, W&N flat clear & Vallejo flat clear.  I prefer Tamiya and W&N to Vallejo.  Vallejo doesn't spray well.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
Posted by Tojo72 on Wednesday, April 29, 2015 3:45 PM
I airbrush Modelmaster Lacquer Flat
    April 2012
Posted by pianodog on Wednesday, April 29, 2015 4:29 PM
Thank you so much Chris I like the Tamiya brand, I will check them out.
On The Bench:
Moebius Penguin
Moebius Robin
    April 2012
Posted by pianodog on Wednesday, April 29, 2015 4:30 PM
Tojo72 don't know that brand very well, I will read about it and maybe give a test flight, thanks for the tip.
On The Bench:
Moebius Penguin
Moebius Robin
cml
    March 2007
Posted by cml on Thursday, April 30, 2015 2:15 AM
I use Gunze H30.
Chris
    April 2004
Posted by Jon_a_its on Thursday, April 30, 2015 3:53 AM
Pledge/Future/Kleer/etc cut with small amounts of Tamiya X21 Flat Base, will turn it mat or semi, depending on mix.
X21 is an opaque past you add to gloss to get it to mat/semi-mat down.
You don't need 10% to get it mat though, I mix up a batch in a 35mm film canister, test spray, & adjust +/- if needed.
I have used it with Original Kleer, but not the newer ones, so test first!
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
Posted by Don Stauffer on Thursday, April 30, 2015 8:48 AM
There are cans of acrylic clear flat at hardware stores. It is pretty thick- needs to be thinned a LOT.
    April 2012
Posted by pianodog on Friday, May 1, 2015 12:28 PM
Thank you all for you kind help, I order the Mr. Color because I am using the paint from that manufacturer, however I appreciate all your input
On The Bench:
Moebius Penguin
Moebius Robin
    December 2009
Posted by Tucohoward on Saturday, May 2, 2015 7:19 AM
Why not Mr. Color clear flat? That's what I use.
Jay
The Mighty Mo says no.
