Gary - Sorry for the delayed response. I wondered about it myself, "is it a true lacquer, or not." Experience tells me enamel over lacquer is OK, lacquer over enamel not. I emailed Testors, they responded quickly, it's a finish that can be safely applied over enamel. That didn't make it clear in my mind, is it lacquer or not?
I e-mailed again, is it lacquer or not? They wrote back, "we call it a lacquer, but it can be safely sprayed over enamel."
Now I didn't know any more than when we started. In a final query I asked simply, is it lacquer, or not.? That answer was, "since many consider a final clear finish to be called varnish or lacquer, that's what it's called." Well, alrighty then, this is likely as much I'll learn from Testors.
I had bought all four in the system, marked Lacquer thinner, Clear Gloss, Semi Gloss and Flat. I just gave them all the "sniff test," they do present some different odors between bottles, the only one that smells remotely like lacquer is the clear gloss, and it's not at all a strong odor like lacquer thinner gives off. The odor of the Testors is much like that of Alclad, that's also called a lacquer, but is it really?
I have used the Testors over both enamels and lacquers, haven't tried over acylic as yet. The Clear Gloss seemed a bit critical as to the right thinning required, but once I was comfortable with it's spraying characteristics I ended up with a very nice, smooth finish, I'm happy with it. Did not affect the paint or decals under it.
I don't suspect it's acrylic, but couldn't say with certainty. I agree with you, the MM clears are completely predictable, not touchy at all. Wish I knew more, but don't.
Patrick
