To my fellow forum members,
I recently purchased a bottle of Tamiya Liquid Primer not knowing that the base is lacquer. My questions are;
1) Can I use enamel thinner to thin this primer for use in a airbrush?
2) Is it safe to use this in a airbrush?
3) Once this primer cures, can I airbrush enamel flat paints over a lacquer base product?
The 99% of my inventory in regards to paints is either Testors and or Testors Model Master paints. The 1% that's left is this Tamiya primer. Thank you in advance.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world. Mrs. Toshi
--> You need to use lacquer thinner.
--> The AB will be safe. For your own safety. wear a respirator and get a spray booth.
--> Yes.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
To Chrisk-k
Thank you for the information, I will continue the process. This helps me very much!
You can clean it up, even after curing, with denatured alcohol (not Isopropyl). At a pinch, you can also thin it with denatured alcohol.
To Phil_H,
Thank you for the information, I'm learning something new every day. Thanks for the read and reply.
I thin the Tamiya primer with their own lacquer thinner.
www.ebay.com/.../161123717731
Tamiya lacquer thinner is VERY mild and doesn't damage the model surface. For me, one bottle lasts for years.
I use hardware store lacquer thinner or denatured alcohol to clean my airbrush after shooting Tamiya primer.
WIP:Academy F-18 (1/72)
On Deck
MH-60G 1:48 (Minicraft)
C-17 1/144
KC-135R 1/144
Academy F-18(1/72)
Ting Ting Ting, WTF is that....
PeachesOff topic but related to Tamiya, is that close to Mr Surfacer 500 or 1000???
I didn't know Tamiya primer can be thinned/cleaned with denatured alcohol.
Thanks Phil for the great tip -o-the-day.
