Airbrush thinner?
    February 2005
Airbrush thinner?
Posted by JerB on Sunday, May 10, 2015 10:48 AM
Hi Guys
I have always used acrylic paints when airbrushing but want to move into some solvent based paint airbrushing. What in your guys opinion is the wayt to go as far as thinner? I see the testors stuff at the hobby shop ( the one in the can ) I also see they have a bottle of the thinner and brush cleaner and didnt know if that could also be used to thin paint. The line of paint Id mostly be spraying is model master.
Any tips would be great thanks
Jeremy
Posted by Don Stauffer on Sunday, May 10, 2015 11:05 AM
I find Testors thinner the best for thinning their enamels, but at times I have found it hard to find the cans, which are more economical.  I have learned to use Mineral Spirits or Turpentine- it is okay, but I can get a slightly better, easier finish with the Testors stuff.  So I get the Testors cans when I can, otherwise use the turpentine.
    February 2005
Posted by JerB on Sunday, May 10, 2015 11:38 AM
Thanks Don
What do you guys think is the best to clean a airbrush after using acrylic paint? I have always like shooting windex afterwards through it and then washing right away with warm water. I have heard is one its the best cleaners for acrylic you just dont want to leave it on the airbrush for a long time or it could attack chrome.
I just usually shoot it threw and scrub the parts with a microbrush and windex and rinse.
Posted by Texgunner on Sunday, May 10, 2015 12:14 PM
Here's another vote for Testors Model Master paint thinner for airbrushing enamel.  I use it to thin any brand of enamel paint for the AB and use regular paint store paint thinner (aka mineral spirits) for enamel cleanup.  Oh, I have thinned enamel for ABing with mineral spirits but as mentioned, I too get a better finish with the Testors stuff.
Gary
"All you mugs need to get busy building, and post pics!"
    March 2010
Posted by Nathan T on Sunday, May 10, 2015 12:36 PM
91% Iso alcohol will clean any and all acrylic paints from your airbrush, and won't attack any brass parts.
    February 2005
Posted by JerB on Sunday, May 10, 2015 12:58 PM
Thanks Nathan,
A quick spray of windex wont hurt will it? 91% is hard to find around here. Sometimes you will see it then you wont.
    March 2013
Posted by patrick206 on Sunday, May 10, 2015 2:21 PM
JerB - If you're writing about the Testors "Universal Enamel Thinner" in the 1/2 pint red can, yes it works well, I imagine ingredients blended for optimal performance within the Testors brand. I have it and use it, but when this one is finished I won't be replacing it with the same.
Over the past few years, like others I have found the mineral spirit thinners to work quite well and I get even better adhesion with them, I suspect they are a bit "hotter" than the Testors. For my use, it reduces the risk of paint lifting when removing masking tape. Out of curiosity I used a spare styrene canopy and with a moistened cotton bud swiped a bit of the Testors on it, zero effect.
I did the same with the paint store enamel thinner, (DuPont,) and indeed it did create a bit of a haze. It had clearly mildly etched the plastic, A couple of light swipes with a 12000 polishing pad restored it perfectly, but as stated it did etch the surface slightly, so it is a tad bit hotter. That actually works to my advantage for a good "bite", and my favored brand of enamel is Model Master.
So, the DuPont thinner works without faults for me, no negative effects ever noted. Where I find fault with the Testors is the price, over ten bucks for such a tiny amount, a full quart of the DuPont is less than eight bucks at the paint store.  The ten bucks is not a major issue, but it goes against my grain to pay many times more in volume for something, than another equally suitable product that is readily available.
For cleaning after spraying acrylics, I like lacquer thinner or 91%. If I encounter a stubborn bit, acetone is aggressive and it's gone pronto. But care is needed to not leave o rings or seals exposed to it, after cleaning with acetone use 91% or lacquer thinner.
Patrick
    July 2004
Posted by stikpusher on Sunday, May 10, 2015 4:58 PM
Another vote for the Testors Enamel Airbrush thinner here. It works great with all the enamel paints that I have airbrushed: Testors Model Master, Humbrol, Pactra, Xtracolor, Revell, Floquil, Aeromaster...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    December 2011
Posted by Chrisk-k on Sunday, May 10, 2015 9:09 PM
Nathan T
It doesn't clean Vallejo acrylics.  That's why I no longer spray Vallejo acrylics (plus Vallejo doesn't spray well).
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, May 10, 2015 9:19 PM
I use Testors Universal Acrylic Thinner when for thinning & cleaning my airbrush when using Model Master acrylics.
    July 2004
Posted by stikpusher on Sunday, May 10, 2015 9:41 PM
Yeah, but unfortunately, there is no such critter as universal acrylic thinner. What works with some acrylic paint brands does not work with others. Some thinners when used with other brands will give you an instant globby mess instead of thinned paint. With Acrylics you really need to use the brand recommended thinner.
       - Plankton
LSM
    September 2003
Posted by checkmateking02 on Sunday, May 10, 2015 10:48 PM
I've not had any bad results using lacquer thinner with MM, Humbrol and Colourcoats for air brushing.  It's "hot" enough to grip the plastic and doesn't usually lift after masking.
    July 2004
Posted by stikpusher on Sunday, May 10, 2015 10:59 PM
I don't remember ever having any enamel lift from masking once it has dried... Acrylics on the other hand... Some yes, and big time... Others far less...
       - Plankton
LSM
    January 2013
Posted by BlackSheepTwoOneFour on Monday, May 11, 2015 9:21 AM
I agree stik. I will only use Testors brand universal acrylic thinner when using Model Master acrylics. The same when using other brand acrylics using their brand thinners. I'd rather be safe than sorry. :)
    August 2012
Posted by JMorgan on Saturday, May 23, 2015 1:17 PM
The brush cleaner is not as good as the Testor's airbrush thinner which has a retarder in it that slows drying time. Testor's brush cleaner can be used as a wash since it is not as corrosive as airbrush thinner and won't affect a dry enamel basecoat. Good luck.
    February 2016
Posted by Sedona Shipbuilder on Sunday, February 21, 2016 9:13 AM
HI; new member here. Is there a generic thinner and airbrush cleaner for Vallejo Model Color acrylic besides water? I see posts mentioning Windex, hydrogen peroxide, 70% IPA, and home brews but I also see posts about anything but Vallejo thinner and cleaner gumming up the brushes and airbrush. I decide to try acrylic because I figured it would easy clean up, but now I'm wondering if it was a good decision.
Dennis
Model in progress: USS Oregon 1/225 by Glencoe
    April 2008
Posted by spiralcity on Wednesday, February 24, 2016 11:16 AM
Sedona Shipbuilder
Vallejo thinner is the best choice, some say it's the only choice, but I have recently discovered Createx Airbrush cleaner works very well as a thinner for Vallejo. Do not use any alcohol releated thinners, this stuff has an adverse affect on Vallejo paints, causing them to gum up and seriously clog your gun. Water will work, but is not really recommended as a good source.
