One technique to rule them all?
    April 2015
Posted by Mopar Madness on Sunday, May 24, 2015 8:28 PM
Ok, so I’m winding down my first build in 20 years.  My little 1/72 Airfix FW-190 is primed and ready for the next step, either body paint or pre-shade.  This is where I’m stalling.  There are many painting and finishing techniques well documented in the forums, in the magazine, and on the web.  Pre-shading, post-shading, pin washes, etc…  There’s even an uber-informative article in my latest issue of FSM that instructs me on how to paint a mottle camouflage.  Thank you FSM, it’s perfectly timed for my build!  My question, is there a certain style of painting and finishing that’s better or worse for certain scales, colors, style of plane, etc…?  For instance, would a painting and finishing style for a 1/72 FW-190 painted in a dark green RLM 70 work just as well on a 1/32 BF-110 painted in sandy RLM 79?
Thanks in advance for your help.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
Posted by Don Stauffer on Monday, May 25, 2015 9:01 AM
Pre-shading of panel lines can be disappointing on dark finishes- it works best with lighter finishes.  For dark paint, a pinwash may work better for panel lines- a slightly different look, but more realistic for these darker colors.
I don't find scale makes much difference.  Color of paint, the type of weathering you are trying to depict, are more important.  And bare metal finishes are considerably different for weathering and other effects.
    April 2015
Posted by Mopar Madness on Monday, May 25, 2015 9:47 AM
Thanks Don.  Its all quite overwhelming, especially when half the plane is dark and the other half is light.  However, I see your point with dark paint underlayment.  Thank you for your help!
Chad
On deck: Who knows!
    August 2012
Posted by AndrewW on Monday, May 25, 2015 1:22 PM
If this were me, I would start with a layer of the callout color.  I would next highlight between panels using a pale shade.  I prefer a tan for brown or green, greys for a blue, or that callout color mixed with a bit of white, maybe 40 or 50 percent.  Then I would lightly cover with a very thin layer of callout color,  just until the highlight shows but is no longer defined.  Then a pin wash of panel lines.  That would be my 2 cents, for what it is worth.
Life is hard, it's even harder when you're stupid - John Wayne.
Posted by Bish on Monday, May 25, 2015 1:35 PM
As Don suggests, the scale doesn't really make much difference in most cases. Though if doing mottling, you may have to adjust how you use your airbrush. The spots on a 32nd aircraft will look out of place on a 72nd. Thinner ratio's and pressure may also need to be adjusted.
I use the same methods on what ever the scheme I am doing, the only thing I adjust is the colour I am using for weathering, dependant on the colour I am putting it on, and how heavy the weathering is dependant on what result I want.
    April 2015
Posted by Mopar Madness on Monday, May 25, 2015 2:16 PM
Thank you guys. I really appreciate the help. I'd like to try the method of fading the panels Andrew but my airbrush skills need much improving! I saw a great BF 110 build article utilizing that method and the final product looked absolutely superb. I'll definitely give it a go once I'm more confident in my technical ability!
Chad
On deck: Who knows!
