Are Metallic Paints Corrosive?
    December 2011
Posted by Chrisk-k on Wednesday, June 3, 2015 5:17 PM
I've read somewhere that metallic paints such as "Alclad 2" and "Vallejo Real Gold" are corrosive, and that a dedicated airbrush is recommended to spray those paints.  Is this true?
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    October 2007
Posted by Milairjunkie on Wednesday, June 3, 2015 5:29 PM
Don't believe so, I've used plenty (Alclad anyway) & never had an issue.
Posted by Texgunner on Wednesday, June 3, 2015 5:30 PM
I'd throw the BS flag on that.Whistling
"All you mugs need to get busy building, and post pics!"
    July 2004
Posted by stikpusher on Wednesday, June 3, 2015 5:57 PM
Considering all the crud regarding simple labeling in the hobby paint world today, I say that is highly unlikely. Just look at the recent Tamiya & Gunze label drama, and how the bottles of Model Master are now having tiny print full wraparound labels, with all associated health and safety warnings... Now I can see airbrush clogging issues due to not so fine metallic pigments, or some issues with caustic thinners, but the paints themselves being corrosive, nope.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    December 2011
Posted by Chrisk-k on Wednesday, June 3, 2015 6:03 PM
The reason why I asked was I was going to buy some Alcald 2 paints for the 1st time in my life.  Anyway, are metallic pigments typically larger than non-metallic ones?  If so, I'll use a HP-CR (0.5 mm nozzle) rather than a HP-CS (0.35 mm) to spray Alclad 2.
    February 2013
Posted by tomwatkins45 on Wednesday, June 3, 2015 8:44 PM
I use a  .3 needle in my Grex TG to spray Alclad and Metalizer. It works fine, so I don't know that a .5 would be necessary.
Tom
    December 2011
Posted by Chrisk-k on Wednesday, June 3, 2015 10:14 PM
OK. Then, I'll spray with my HP-CS because it sprays smoother than my HP-CR.
    October 2007
Posted by Milairjunkie on Thursday, June 4, 2015 9:12 AM
I've used it through both 0.15 & 0.2 H&S nozzles without issue, the "metallic" in the paint is very fine.
Posted by Don Stauffer on Thursday, June 4, 2015 9:19 AM
Depends on what you mean by corrosive.  It will not cause corrosion to a structure it is applied to.  Aluminum does corrode, but the oxide is relatively transparent.  As it corrodes and the thickness of the corrosion builds up, it will lose a bit of sheen. I am assuming the vehicle of Alclad greatly slows corrosion, but even if it does corrode, since any but the polished aluminum is already a bit dull, I  would assume it would be many years before you'd notice any change in gloss on those. I suspect the polished aluminum, if applied over a really good base to give it a highly polished look, might eventually loose some gloss.  But I have some really shiny planes with a very polished look with polished aluminum that are about seven years old, and they are as shiny as the day I finished them.
    July 2013
Posted by modelmaker66 on Friday, June 5, 2015 12:05 AM
Alclad actually sprays better than anything else including Tamiya.
    October 2008
Posted by P mitch on Friday, June 5, 2015 2:28 AM
All I would say is with Alclad get a gravity feed brush its much easier with one.
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    January 2013
Posted by BlackSheepTwoOneFour on Friday, June 5, 2015 9:24 AM
modelmaker 65 -
Alclad specialty is metallic lacquers and translucent colors. That's like comparing apples to oranges with Tamiya. LOL! Actually, Tamiya is a great product to airbrush with.
