Trying to Airbrush Crisp Fine Lines
    December 2011
Posted by Chrisk-k on Thursday, June 4, 2015 8:02 PM
I've been practicing airbrushing fine lines because I plan to apply a German worm camo pattern in the near future.
My problem is as follows:
Using Tamiya acrylics thinned 50-60% (my normal thinning ratio), I cannot airbrush fine lines.  It seems the paint is too thick for a low psi (5-10 psi) using my Iwata HP-B plus (0.2mm nozzle).
Using Tamiya acrylics thinned 75-85%, I can airbrush fine lines.  However, the heavily thinned paint makes fine lines look very dim and faded.
I know that enamels use finer pigments.  So should I airbrush fine lines with enamels?  If you can airbrush crisp fine lines with acrylics, let me know how you do so!
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    March 2010
Posted by Nathan T on Thursday, June 4, 2015 8:25 PM
I don't use Tamiya paints. Most of my paints are Gunze Acrylics. I find that a higher pressure actually helps, somewhere around 14-16 psi, with a 70/30 thinner to paint ratio. Also, you will need to build up your fine lines with multiple passes if you thin your paint too much.
    December 2011
Posted by Chrisk-k on Thursday, June 4, 2015 8:43 PM
OK. I'll try with a higher PSI.
    July 2013
Posted by modelmaker66 on Thursday, June 4, 2015 11:55 PM
Nathan's answer is perfect. You could also try thinning Tamiya with lacquer thinner. It sprays far better and smoother and finer then.
    March 2013
Posted by patrick206 on Friday, June 5, 2015 3:56 PM
I haven't been using Tamiya acrylic all that long, but have good results thinning the following ways.
71% alcohol and a couple of drops of Liquitex Flow Aid. Tamiya does accept considerable thinning, I thin to around 30-40%, still get good coverage. I too find that the best results are to be had at 12-16 psi, that gives me a better spray pattern and flow on the surface. Too little pressure seems to not break the paint up enough, I have better results with a finer spray mix.
I have used Liquitex Slow Dri, in some complicated instances that seems to assist with preventing partial drying prior to reaching the surface. Also Tamiya X20-A seems to work well, I think it might have some flow aids and/or retarders in it.
    September 2012
Posted by GMorrison on Friday, June 5, 2015 3:58 PM
Very useful information, thank you all.
    December 2011
Posted by Chrisk-k on Friday, June 5, 2015 4:13 PM
I use Tamiya lacquer thinner for spraying camo patterns.  You guys are right.  When I spray at 15 PSI, I get much crisp fine lines.
I'm not sure why I kept using a super low PSI; I must have read somewhere that detail airbrush work needs a low PSI...
Posted by Tojo72 on Friday, June 5, 2015 4:39 PM
Wait i'm confused. it says X-20 is Enamel Paint Thinner mainly spirits, X-20A is the Acrylic which is alcohol based.Here is an old post,so which is best used with which ?
cs.finescale.com/.../148449.aspx
    December 2011
Posted by Chrisk-k on Friday, June 5, 2015 6:00 PM
Oops...a typo.  I corrected it.  I use Tamiya lacquer thinner for spraying camo patterns and X-20A (acrylic thinner) for spraying a base coat.  The reason is (1) Tamiya acrylics can be heavily thinned with lacquer thinner, and (2) I don't need to thin heavily for a base coat and want to minimize the use of lacquer thinner although I have a spray booth.
Posted by Tojo72 on Friday, June 5, 2015 6:12 PM
So your regular Tamiya colors like XF-60 and XF-64 which I use for German armor,can be thinned with either ?
    December 2011
Posted by Chrisk-k on Friday, June 5, 2015 6:58 PM
Yes, Tamiya acrylics can be thinned with lacquer thinner or X-20A.  Using lacquer thinner results in a slightly smoother finish.  X-20 is enamel thinner and can't be used with acrylics.
    November 2008
Posted by plasticjunkie on Friday, June 5, 2015 7:05 PM
Chrisk-k
I read somewhere an article where the builder sprayed the fine worm lines with Tamiya acrylics at 20-30 psi. I personally can't get the control with acrylics as I do with enamels which I spray about 50/50 mix at 5-10 psi. I would assume you need more psi to cycle the acrylic paint then.
 GIFMaker.org_jy_Ayj_O
    August 2005
Posted by Phil_H on Friday, June 5, 2015 7:10 PM
X-20 is enamel thinner (very much like mineral spirits). X-20A is acrylic thinner. Tamiya Lacquer thinner is called just that, it doesn't have an "X" number.
    March 2013
Posted by patrick206 on Friday, June 5, 2015 7:22 PM
Phil H - That sounds correct, at my local shop I see X-20A and Tamiya Lacquer Thinner, (there is no "X" designation for that product. But I've never seen them carry X-20, so I can't remark on just what it's application is.
    August 2005
Posted by Phil_H on Friday, June 5, 2015 7:31 PM
patrick206
You won't often see X-20 in the US as it belongs to Tamiya's enamel paint line, which (as far as I know) isn't sold in the US. The enamel paints come in squat rectangular-sided jars like the Testors paints of old. If you do see them, they may be a grey import.
As far as I know, Tamiya Lacquer thinner is only sold in the 250ml jugs
    December 2011
Posted by Chrisk-k on Friday, June 5, 2015 7:54 PM
Heck, I somehow thought Tamiya lacquer thinner was called X-20.  I was wrong.  It simply says "Lacquer Thinner" with no product number.  I've corrected errors in my above posts.  Sorry about confusion.
This is Tamiya lacquer thinner. I still have 4 unopened bottles.
https://www.scalehobbyist.com/catagories/Paint_and_Construction/lacquer-thinner-250ml/TAM00087077/product.php?kw=lacquer,thinner
Posted by Tojo72 on Friday, June 5, 2015 8:43 PM
Chrisk-k
Chris,Seems there is a Tamiya X-20 also
http://www.ebay.co.uk/itm/Tamiya-80040-Tamiya-Color-Enamel-Paint-Thinner-X-20-250ml-/371110592526
http://www.ebay.com/itm/Tamiya-80030-X-20-X20-Oil-Based-Enamel-Paint-Thinner-/220763385164
So what does Tamiya sell three diffrent kinds of thinner ? this is getting interesting.
    December 2011
Posted by Chrisk-k on Friday, June 5, 2015 9:37 PM
X-20 is for Tamiya enamels
X-20A is for Tamiya acrylics
"Lacquer Thinner" is for Tamiya spray can lacquer paints but works extremely well with acrylics.
Posted by Tojo72 on Saturday, June 6, 2015 6:02 AM
Okay thanks
