No Propellant
    June 2015
No Propellant
Posted by modelmadman58 on Thursday, June 11, 2015 2:59 PM
How can you get the paint out of a spray can that has lost its propellant? Thanks!
Posted by Don Stauffer on Friday, June 12, 2015 9:48 AM
Only way is to remove paint by ruining can.  Here is the method I use which I think is pretty safe.  To be sure all propellent is gone, I hold down nozzle to prevent buildup of pressure while I take a sharp punch and punch a big hole in can.  I then clean up the hole with a reamer to smooth edges of hole. I let it sit for awhile to make sure any residual propellent boils out of paint and then pour out paint through hole.
    August 2008
Posted by tankerbuilder on Friday, June 12, 2015 11:41 AM
You are right on there , DON  T.B.
    June 2015
Posted by modelmadman58 on Friday, June 12, 2015 10:36 PM
Thanks for the info! I will do this.
