air brush spitting paint
Posted by urich on Wednesday, July 8, 2015 9:21 AM
A little back ground. I have a Itwata Neo Ab with a Sparmax compressor with a moisture trap at the AB and I'm using Model Master enamel paint I also use Badger Model Flex water based paint and I'm painting inside in a air condition room. Here is the problem both paints have started to spit when I try to paint will paint good for a few seconds then out of no were it will spit a fine but noticeable spots. it will spray thinner and water no problem just paint at all pressures I'm having the problem with. I've cleaned it several times with no luck. Now I'm at a stopping point on both my railroad and model aircraft projects. thanks for any help J.
    May 2013
Posted by Greg on Wednesday, July 8, 2015 10:15 AM
First thing I'd do is check the needle tip for damage/splitting under the highest magnification you have.
Also, this sounds pretty dumb but have you discharged your moisture trap? I had some spitting a year or so ago, and to my surprise and I still don't know why, my trap was full of water.
Just a couple ideas for you until the real airbrush experts chime in.
    December 2011
Posted by Chrisk-k on Wednesday, July 8, 2015 10:41 AM
It sounds like the nozzle or needle tip is damaged.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    June 2014
Posted by USAFASME7 on Friday, August 7, 2015 1:58 PM
It could be any number of things, but Airbrushes are nothing more than tiny paint spray guns. Same parts, same theory of operation. If a spray gun spits or sputters, one of the first things to check is that all the fittings are TIGHT, and that the air cap and fluid tip (on the end of the airbrush) are also tight. Anything loose breaks the vacuum pressure and causes inconsistent spraying.
I teach (real) Aircraft painting for a living.
--Rob
Glue Sniffer since 1977
    March 2013
Posted by patrick206 on Friday, August 7, 2015 5:23 PM
Several possibilities, among them: Paint residue remaining in front end parts , split tip/nozzle, bent needle tip, rubber "O" ring damaged. Try a really thorough dis-assembly and cleaning, then a close visual inspection of the mentioned parts. I once experienced a very tiny split in the nozzle, required high magnification to find it. It was the Sotar from Badger, the airbrush was non operable with the split, replacement returned it to like new function.
Visit Don Wheelers airbrush website if you have not already, worlds of AB info to be had there, including the one you have. Good luck with the fix.
Patrick
    November 2008
Posted by plasticjunkie on Friday, August 7, 2015 6:07 PM
I own an Iwata Neo also and it just sprays beautifully. Have you properly stirred and thinned the paint? What psi are you using? Thick paint and low psi will cause this problem. Another issue may be bad paint. Have you tried others to see if there is any change?
 GIFMaker.org_jy_Ayj_O
