Hello Don,
Thank you very much for your reply!
The only Alclad paint that I am having issues with are the Aluminium and the Dark Aluminum all the other ones that I have spray out just fine and I tested on the smooth side of a CD, not the rough side.
When I lower the pressure and gently pull back on the trigger, nothing comes out until I pull all the way back and if nothing comes out I then have to increase the PSI and then when it finally comes out I do not appear to get a good flow resulting in a textured finish.
I will try what you suggested and keep you posted.
Also would it be OK to thin Alclad Aluminium using lacquer?
Thanks
Gary
