Testors Flat Black vs Model Master Flat Black
WZ2
Posted by WZ2 on Saturday, September 19, 2015 10:08 AM
Sometime I get the Model Master flat black due to the larger size bottle.   If I air brush the MM flat black more than a couple coats it seems to get progressively glossier.   Am I seeing things?   Is the Testors flat black different from MM?   I don't seem to have this issue with the Testors flat black.
Thanks!  Chris
    July 2004
Posted by stikpusher on Saturday, September 19, 2015 11:31 AM
It would not surprise me. In my experience, in the past few years, MM paints seem to have some quality control issues, especially regarding flats losing that quality, or paints simply going bad and un usable as they sit.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2014
Posted by Silver on Saturday, September 19, 2015 12:43 PM
Add a couple of drops of lighter fluid to the mix and problem solved.
Posted by Don Stauffer on Sunday, September 20, 2015 11:23 AM
The flatness/sheen of black paints varies with the application.  Flat paint can go semi-gloss with thicker coats, gloss paint goes semi-matt with a dry, thin coat.  If you build up flats with several coats they will tend to have more sheen as it is harder to put down a dry coat.
WZ2
Posted by WZ2 on Tuesday, September 22, 2015 9:03 PM
Dunno, I bought some Testors flat black and hit my project with it and it laid down nice and smooth and flat.  I'm still suspicious of the MM flat black.
Chris
    August 2005
Posted by Phil_H on Wednesday, September 23, 2015 2:48 AM
Has the paint been thoroughly stirred before thinning for airbrushing? Stir well, do not shake.
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, September 23, 2015 9:43 AM
WZ2
Chris
Not if you learn to stir the paint first rather than shaking the paint bottle.
WZ2
Posted by WZ2 on Wednesday, September 23, 2015 6:49 PM
Maybe, but I generally use the same methods pretty consistently.   Although possibly the larger bottle tempted me to shake it.    I have some MM left.   I'll be sure to stir and maybe squrt some on a test piece.
    January 2006
Posted by dirkpitt77 on Wednesday, September 23, 2015 8:45 PM
Slap some Dullcote on that baby and call it good.
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
