New to airbrushing, some general questions
    June 2015
Posted by djjeavons on Wednesday, September 23, 2015 3:01 AM
Hi
I am relatively new to modelling but have learnt an awful lot in my last few builds and with the help of the great people here. So far, I have been doing autos and have been buying rattle cans for spraying the body and then hand painting everything else.
I have now invested in an Airbrush with compressor and would like to know if the following is possible.
Currently, I am building a Messerschmitt BF 109E-3 (1/32 scale) for a friend, my first plane :) and have done the following so far:
The main assembly was airbrushed with a Tamiya Acrylic XF-1 black (thinned with some water) and the Aluminimum colour (can't remember the code off the top of my head) was hand painted. What I would like to know is if it is possible to airbrush such fine detail or is it normal to hand paint this type of detail?
I assume that if I was to airbrush this detail then it would involve a lot of fiddly masking, but would like to know how the pro's do it.
I have a lot more questions but will ask those as I get further into the build. Especially regarding camo, blotting, washes, weathering and so on. One step at a time Embarrassed
Thanks for any help.
Dave
Posted by Tojo72 on Wednesday, September 23, 2015 6:26 AM
It's probably easier to hand paint the smaller details.Im not a pro,but I would have done the same,when I do armor,that's how I handle it.
    November 2008
Posted by plasticjunkie on Wednesday, September 23, 2015 7:03 AM
I'm not familiar with the FoxHunter KMS Airbrush you bought so I cannot comment on it's performance or quality. I'm sure someone will weigh in on this.
I suggest that you read all the material included and practise to get familiar with your ab. They all perform different so you have to experiment with different paint/thinner/ ratios and psi settings.
Small details like the wiring on the engine or any other molded on detail is best painted by hand unless they are on the parts tree and you want to spray it then attach the individual part. I rather use the Tamiya X20A acrylic thinner as it makes the paint spray better than using a substitute.
 GIFMaker.org_jy_Ayj_O
Posted by Don Stauffer on Wednesday, September 23, 2015 9:21 AM
I also do a hand paint on really small details that would be too hard to mask. If detail is too small for my smallest tip brush, I dip the end of a sharp toothpick in a little puddle of paint and apply paint with that.
I usually get that little puddle by shaking the paint bottle and then removing the cap and set it upside down on my bench.  The paint film that sticks to the inside of cap is just right for dipping a toothpick end in.
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, September 23, 2015 9:42 AM
I recommend that you NEVER thin Tamiya paint using water. Thin using Tamiya airbrush thinner. Otherwise you won't get good adhesion thinning with water. I wouldn't bother doing a wash since you've already thinned Tamiya paint with water. You'll end up wiping away the colors in the process.
    October 2008
Posted by P mitch on Wednesday, September 23, 2015 9:45 AM
Looking at your set up the compressor should probably be fine but you'll want to replace the airbrushes as some point if your going to continue airbrushing. Look at a few of the posts about airbrushes or have a look at Don's website https://sites.google.com/site/donsairbrushtips/ for some ideas. Like most things the more you spend the better things get.
You could reverse your process and paint the engine block silver, mast the parts you want silver then paint black but for what your doing you did the right thing.
Don't be affraid to ask either somone here will always help
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    June 2015
Posted by djjeavons on Wednesday, September 23, 2015 10:19 AM
Thanks for all the quality advice. Pretty much confirmed my thoughts.
Regarding thinners, I have been using enamel paints and have suitable thinners but haven't tried on airbrush yet. I wanted to try acrylics and heard that you could use water so tried while waiting for an order of Tamiya thinners to arrive.
I agree that I will want to purchase a better airbrush and to be honest, this is my second as I started off with a very basic plastic one with propellant cans which was pretty awful. I intend to keep cost low until I get more confident. However, with that in mind, would a better airbrush fit the compressor that I have or would it require an adaptor?
Again thanks for all the help.
Dave
    March 2013
Posted by patrick206 on Wednesday, September 23, 2015 11:28 PM
First, I echo the suggestion to have a thorough look at Don's Airbrush website, massive amounts of info there. Next, I have no knowledge of your airbrush, (USA,) but if it functions at all for you it would be best to learn using it the best you can for experience. Then you'd have some knowledge, to help you decide what type/brand of AB you would want to settle down with.
There are plenty of very expensive AB's out there, as well as many quite reasonable ones. High cost does not neccessarily result in better performance, what will be most important is matching the right AB to your needs. Comfortable to hold, easy and reliable to use, quick and easy to clean thoroughly after use will be importan't features.
It's likely that you can readily find an adaptor that will allow any AB to be mated to your compressor. Try shops that specialize in air tools, air hoses and compressors, they're normally well stocked with fittings. I find it easier and faster to lug the AB and compressor air outlet along, so they can see first hand what is needed to make it useable.
When I sized them up at home, then tried to figure out how I could make it all work, I bought TOO much stuff and ended up with an awkward Frankenstein looking outfit.
Good spraying.
Patrick
    February 2007
Posted by mitsdude on Thursday, September 24, 2015 12:41 AM
Not saying those Aluminum color areas couldn't be painted with an airbrush but it would require a skill far beyond mine or anyone I know. Anyone with that delicate a touch with an airbrush has my utmost respect. You did it the way I would have.
Ola
    September 2015
Posted by Ola on Thursday, September 24, 2015 5:04 AM
I am a beginner myself and have found that youtube is tremendously helpful for figuring out different ways to paint scalemodels with an aibrush!
    June 2015
Posted by djjeavons on Thursday, September 24, 2015 8:36 AM
Ola
100% agree. With YouTube and the videos here I am learning quite a bit :)
