acctingman
Just curious to know what brand(s) the pros here use for acrylics? Is one better than the other? I'll be airbrushing and doing heavy weathering.
For weathering products.....whom do you prefer?
Thanks in advance!
Which brand of acrylics? It depends.
I have Tamiya, Vallejo, Andrea, Model Master, and craft store acrylics. I will use one or the other, depending on the job.
For painting figures, Andrea and Vallejo are purt near unbeatable. They were designed specifically for hand-painting of miniatures. They go on easy, dry to an excellent finish and cover very well. Vallejo also makes a series designed for airbrushing, but I haven't tried those, and I haven't tried airbrushing the Andrea and Vallejo paints that I do have. So I can't speak to how well they may perform when airbrushing.
For ordnance and for figures, I also use Tamiya acrylics. They work very well with an airbrush; they are formulated for airbrushing, I have been told. They also work best, in my experience, when used with Tamiya's proprietary acrylic thinner, whether you want to apply them with an airbrush, or brush them on by hand. I have heard that they can be thinned with lacquer thinner for airbrushing, too, but I haven't tried that . I have tried water, and isopropyl, to thin my Tamiya acrylics, and got very poor results.
Model Master acrylics I also use for ordnance and for figures. On figures, I will often brush them right from the jar, no thinning, onto the subject. On ordnance, I'll airbrush, thinning them with isopropyl. They work OK, too.
And the craft store acrylics serve as good utility paints. I've thinned them with water or with isopropyl, for hand-brushing and for airbrushing. I found that they're not as good for airbrushing, because they tend to have coarsely-ground pigments, and so the resulting finish is a little rough. But they are great for washes and for other weathering techniques. And the work well enough for figures.
For weathering products, I make my own. Although I appreciate that the commercial makers take the guesswork out of it, and that appeals to new guys and some experience modelers, I'm not about to pay Mig and the rest for things I can make myself. Pastel chalks provide weathering powders, and paints and thinners provide washes and weathering fluids. I use oils for filtering.
Hope that all helps!
