hey nomis, dont feel bad my friend, i have about 3 scrap kits that are airbrush fodder. ill be so tedious with the model trying to make a completed project only to screw something up along the way and just put it in the airbrush fodder pile. i had a p-40 that probably had atleast 12 or so coats of paint on it before i chunked it. it was quite fun though! cammo is my passion so i practice the fine line all the time to try and hone my skills for the "real" project im gonna start in the future. along the way, i have tailored the following steps for my personal use and find that it works well from barely noticeable demarkation lines to the obvious demarkation lines.
1. i thin tamiya acrylics down to around 60% thinner 40% paint using the old eyeball technique.
2. crank the psi down to around 12lbs. ( i have a iwata hp-c and a omni 5000 brush)
3. hold the brush at a slight angle pointing inward of the pattern your filling in and ever so slightly begin "drawing" the demarkation line spaying with my crown cap about 1/8 of an inch from the surface.
4. after i have about an 1/4 of an inch thick line of paint all the way around the patch of cammo im spraying, i back off to around 2" from the surface and fill in the middle of the patch ever so slightly building the color to the desired shade.
5. if i slip up somewhere, i put in the base color and touch up until im satisfied with the look.
hope this helps, later.
