Trigger Airbush Cleaning
    September 2013
Posted by Marcus McBean on Sunday, November 15, 2015 12:10 PM
Picked up a cheap airbush (Master Model G79) with a trigger and was wondering if cleaning them is done different than standard brush?  Check on you-tube but was unable to find anything that really talked about how they should be clean.
Marcus
    October 2008
Posted by P mitch on Sunday, November 15, 2015 12:59 PM
Looking at the brush I'd say you clean it the same as a "normal" brush you'll just have a bit more disassembly. The needle should be removed as usual by removing the back of the brush and pulling it backward. The trigger part looks like a screw at the top needs removing but after that looks like everything should just come apart fine. After that break down the front as normal.
I'd be tempted to break it down before you use it the first time if you can just so it all clean
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
