Quietest compressor?
    October 2007
Posted by Darth_Vapor on Sunday, December 6, 2015 7:55 AM
Hi All,
I've recently moved into an apartment building and would like to get my workbench back up and running. The biggest problem seems to be the compressor for my airbrush. My old Walmart garage compressor is incredible loud and would never fly in my quiet building.
Does anyone have any recomendations for a super quiet compressor?
TIA
    February 2014
Posted by Akula on Sunday, December 6, 2015 8:38 AM
Try California Air Tools compressors. A little pricy but dead quiet.
Bob
    October 2013
Posted by infofrog on Sunday, December 6, 2015 9:11 AM
Build one
Rick
walmart
Remove motor, leave tank gauges and pressure switch
Get little refrigrator compresser . Maybe off ebay craiglist . Or a little refrigrator from walmart . Then have hvac tech remove freon ..
Luckly i work as a hvac tech .
Installed on off switch . Finished product . Only issue I had was the one way check valve . I had to take out , remove couple spring loops . The compressor was strong enough for that spring . After that works great . Super queite
Posted by Don Stauffer on Sunday, December 6, 2015 11:59 AM
Quietest options are either to fill a portable air tank in garage and use the tank in your workshop, or go CO2.  I have a Iwata Silver Jet, pretty quiet and not too expensive, that I got just because my previous general purpose pancake compressor was so loud.
    May 2013
Posted by hogfanfs on Sunday, December 6, 2015 3:52 PM
I have an Iwata Power Jet Pro and it's very quiet.
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    May 2009
Posted by Pawel on Sunday, December 6, 2015 4:56 PM
infofrog - nice one!
I have also built my first compressor this way - 20 years ago I couldn't afford any real compressor - and it still works for me to this day! I've actually built like three more since (for my pops and so on), and I say it's probably the best value for money! Very quiet too - if you take it outside, the wind is louder that that compressor - just as loud as a working refrigerator!
Here's the link to one of my babies:
http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/18/p/151920/1628509.aspx
Good luck with your builds and have a nice day
Paweł
www.vietnam.net.pl
    October 2013
Posted by infofrog on Sunday, December 6, 2015 5:05 PM
Pawel
Paweł
Thats awesome . Same here on the compressor job . If this one goes down , I will go to the supply house buy a new 1/3 hp compressor and build something more like yours.
My ebay cheap compressor went down . I wanted a silnet compressor with tank . I almost bought one  for $ 550 . I thought about it . So I built a basic one . I had it almost year now . My pressure switch is going bad . I will order a new one .  9 dollar switch
Best operation compressor I ever had .
Rick
    August 2011
Posted by GreenThumb on Sunday, December 6, 2015 6:36 PM
I have a Badger Million-Air. Super quiet.
Silentaire also makes some very quiet compressors but quality does not come cheap.
    May 2009
Posted by Pawel on Monday, December 7, 2015 6:52 AM
Hello!
Rick - thanks a lot! The one I posted pictures of was designed to be used modular - with or without tank (like for tire pumping), or for the tank to be taken away if you needed a small amount of compressed air without the need to tug the compressor with you.
GreenThumb - while I agree that quality has to cost, I believe in making quality myself. Making a "fridge" compressor has the potential to save you some money at the same time giving you a tool tailored to your specific needs.
Thanks fr reading and have a nice day
Paweł
www.vietnam.net.pl
    April 2007
Posted by JTRACING on Wednesday, December 9, 2015 5:49 PM
I also use a fridge compressor, a super old one from the 70s works like a champ.
i just turn it on when I need to fill my large air tank and then unplug it, no fancy switches or anything, just the wall plug and an air line with a quick disconnect
    October 2007
Posted by Darth_Vapor on Thursday, December 10, 2015 7:52 AM
Thanks everyone. These are all good options.
    November 2013
Posted by Spitfire on Thursday, December 10, 2015 12:38 PM
Does the fact of a compressor being single or double piston have anything to do with noise level?
    May 2009
Posted by Pawel on Thursday, December 10, 2015 1:46 PM
Hello!
It is some kind of a factor, but not the most important, I'd say. Stiffness of all structural components and routing of the air canals, and also drive motor noise levels are more important here.
Good luck with that compressor
Paweł
www.vietnam.net.pl
Posted by Don Stauffer on Friday, December 11, 2015 9:21 AM
When I was looking for a quiet compressor about a year ago, I went to the mfg's web page for each compressor I was interested in.  Most gave the decibel rating of the compressor.  If the mfgr did not post that figure I immediately ruled it out.
    January 2016
Posted by ardvark on Saturday, February 13, 2016 10:20 AM
hi i use a paasche d3000r, very quiet..great compressor, a little pricey, i got lucky and landed mine from a pawn shop. look an work like new.
    January 2007
Posted by oldsalty on Saturday, February 13, 2016 11:36 AM
You know this is an old thread? Check the date.
OldSalty
    January 2007
Posted by oldsalty on Saturday, February 13, 2016 11:44 AM
As I mentined on the other thread TCP compressors are cheap, quiet and good, had it for 8 years now.
OldSalty
