Airbrush stuck ? HELP!!!
Posted by Anonymous on Sunday, March 14, 2004 10:50 AM
Hey guys need your help have a problem with the paasche h model airbrush Its stuck on blowing air without pressing top button even when releasing it...jorge
    December 2003
Posted by hunterw450 on Sunday, March 14, 2004 11:02 AM
sounds like maybe the pin mechanism that lets the air in through the hose is stuck. did that make sense? some times i can see it in my head but can' t explain it. anyway maybe u should put a little airbrush oil on it ( the moving pin part). most airbrushes operate pretty much on the same premise, but then again i don't have that model of airbrush so maybe someone else can be more specific.
Posted by Anonymous on Sunday, March 14, 2004 1:02 PM
Something is not working or stuck in the Finger Lever Assembly. Check it by removing the airline from the airbrush. Then unscrew the valve nut. Check the spring, valve plunger and valve washer. Clean and replace as needed.
http://www.paascheairbrush.com/parts_2003/HHSAirbrushPartsList.pdf
