Tamiya Polycarbonate paintings
    October 2011
Posted by HEAVYGUNS155 on Monday, December 21, 2015 8:12 PM
Can paint for polycarbonate be used on regular styrene plastic?
    November 2003
Posted by mississippivol on Monday, December 21, 2015 8:26 PM
If the paint is intended for r/c cars, then probably not. It's too hot for the plastic.
    August 2005
Posted by Phil_H on Monday, December 21, 2015 11:30 PM
mississippivol
In the case of Tamiya's bottled PC paint, actually they're not too hot for styrene. They're water soluble, like the regular acrylics.
There is only a limited colour range, most of which can be found in the regular acrylic range.
They differ in being more latex-based and much thicker than the regular paints, as they need to flex with the PC body shells when the body takes a hit. Because they are meant to be applied to the inside of the shell, the shell itself imparts the gloss to the finish. The finish on the paint itself is a dull eggshell.
The PC spray paints could well be hotter than the regular Tamiya spray cans, which are already quite hot in themselves. Again, they dry to an eggshell-like finish.
Personally, I wouldn't use PC paints of any description on styrene.
