Here is my idea to reduce/elimate overspray with what I call the overspray shield. The blue area is a simulation of painted areas.
My test design will involve two hollow tubes on the side of my airbrush. A peice of styrene would be attached to two rods which would be able to slide in and out of the hollow tubes so you can get closer, farther, or completely remove the overspray shield. You can make shields in any shape, too.
Thoughts or comments?
