Hey guys,
I currently own a Badger 200 (old model) as well as a Badger 350. I've had both for years but haven't used them much because I haven't done a lot of modeling over the years. I'm getting into it full force now and have been using them more regularly with satisfactory results but I do have one small issue/annoyance.
I find that during the course of a build, I have a number of small parts where only 2 or 3 of which need one specific color and then 2 or 3 other parts need a different specific color, etc.. It can get tedious because as I'm sure you guys already know, changing colors with a siphon feed AB isn't the quickest/easiest thing to do.
I plan to keep the 200 and continue to use it for larger items like the body, interior, etc. but I would like to get a gravity feed AB with a small cup for doing small jobs.
I've looked around some and considered a number of models. I really looked hard at the Iwata line as I've read many good things about them but decided they are more money than I can justify for my needs and current skill level. I figured that I already have other Badger AB's, hoses, adaptors, etc. and have been happy with them so it probably makes sense to just stick with Badger?
The first on that came to mind is the 200G as it's the brother to the model I already have experience with and know how to use but then I started thinking it may be time to step up to a dual action model?
I'm only doing cars right now so I don't really need a dual action but most experienced AB'er seem to prefer the dual-action type and at some point I plan to start doing military models and the DA style would be better suited for Camo work.
So the one I'm seriously looking at now is the Badger model 100G. Seems like a good, time tested model. I've read Don's review of it and Chicago Air has them on sale for $65 shipped. So before I pull the trigger (literally) is there any other models (or brands) I should seriously consider? Should I get the medium or fine head? I'm thinking for my current needs a skill level the medium is the one to get and I can always order the fine needle/head later if I feel the need?
Thanks
