Cleaning stations are great
    December 2015
Posted by Dash8 on Saturday, January 9, 2016 9:54 PM
Which one are you using ? They really cut
down on the overspray when you flush
your airbrush. I really like design of the
Astek one.
On the bench: Revell Euro Fighter 1/32
Ontario, CANADA
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, January 10, 2016 10:37 AM
I use an empty jelly or peanut butter jar. Cost me nothing. Every spring I take it to the recylcling center for proper disposal.
    September 2013
Posted by blackdog62 on Sunday, January 10, 2016 10:38 AM
I also like having one my dog knocked mine of the bottom shelf which is only 2 inches off the ground and shattered it.
What a pain cleaning with out it. Mine was a iwata made of glass.I will get another one. I would also like a  spray booth.
Posted by Don Stauffer on Sunday, January 10, 2016 11:10 AM
I made my own.  Used a glass pint jar (glass because I sometimes clean up with lacquer thinner).  It had a plastic top.  Then I used some 1/2 inch PVC pipe and pipe fittings, including a 45 degree elbow to form an inlet sticking up and out.  I reamed a hole in the top to fit the pvc pipe assembly and glued the assembly into the top.
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, January 10, 2016 11:23 AM
Don Stauffer
Good tip, Don! I may have to do that to make it universal for all my jelly jar lids. This way, I can save the solid lids for disposal at the recycling center.
    September 2013
Posted by blackdog62 on Sunday, January 10, 2016 1:13 PM
That's what I'm doing more or less at this point looking for a jar that will fit my iwata lid that's left. It works great at breathing and keeping the over spray down.
    October 2006
Posted by JunJon on Sunday, January 10, 2016 9:35 PM
I use to have 2. But I gave it away. Its not really safe for airbrush.
So I got me another 2 of this...
http://www.hlj.com/product/AIWHPA-ACP/Sup
With a tip and mid body support or airbrush holder. This is the best one for me.
Why 2? One for Water based and the other for solvent based paints and cleaners.
All this containers can only contain most of the particulate but not the fume.
    December 2015
Posted by Dash8 on Tuesday, January 12, 2016 9:42 PM
JunJon
Cool idea JJ !
Ontario, CANADA
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, January 12, 2016 9:58 PM
JunJon
Better yet - go to Harbor Freight and find this:
http://www.harborfreight.com/airbrush-cleaning-bottle-68154.html
Cost $7.99. Throw in their 20% coupon and it come out to less than $7. Buy 2 it's still comes out less than $20.
It's basically the same product.
    January 2009
Posted by fermis on Tuesday, January 12, 2016 10:15 PM
I use the Harbor Freight one.
It has an "O" ring to seal around the tip...has another opening, filled with a mesh "sponge"/filter...but will not contain the fumes as you spray...so I hold it right under the suction fan, blowing that junk outside.
