What airbrush are you using ?
    December 2015
Posted by Dash8 on Tuesday, January 19, 2016 10:01 PM
I am using a BD-130 with a .3mm needle, it nails
Testor's acrylics, the BD-130 is great bang for the buck.
On the bench: Revell Euro Fighter 1/32
Ontario, CANADA
    June 2010
Posted by 5-high on Tuesday, January 19, 2016 10:13 PM
Dash
Tonight I'll be using my new badger 155 anthem to freehand the camouflage pattern on my trumpeter mustang mk.lll
Had it in the case for close to 10 years .
Pete
    December 2015
Posted by Dash8 on Tuesday, January 19, 2016 10:27 PM
5-high
Dash
Pete
Cool Pete !
Ontario, CANADA
    January 2016
Posted by Microbike on Tuesday, January 19, 2016 10:29 PM
I have a ten airbrushes of which seven are single action Badger 200 series some I bought cheap for spares many years ago - problem is that Badger never wear out - they really great Airbrushes (five of the ten are Badger that I haven't used yet but they there should I need them)
For 95% of my work I use my trusted Badger 200IL which I have been using for 35 years. Last year I sent it to back to Badger for an overhaul which they did replacing internal bushes, needle and the nozzle all absolutely free even posted it back to me in the UK for free - I was flabbergasted at such great service - so now I carry on using it and will outlast me I think
I have a Holbein double action that I use only for Al-Clad chrome and it produces a fantastic mirror finish - not sure why - it just does chrome literally perfectly
i bought an Iwata double action but found it didn't spray as well as the badger so don't really use it - it's parked
i have a double action Badger Renegade but haven't used it yet - it's a work of art just haven't plucked up the courage to use it and as yet - also haven't found a job for it that the Badger 200 or Holbein can't do
    May 2013
Posted by hogfanfs on Wednesday, January 20, 2016 7:54 AM
I have two Iwata Hi-Line airbrushes, HP-AH with .2mm needle and a HP-CH with .3mm needle. I really like these two airbrushes, I have control of the air-pressure directly on the airbrush.
Dash,
I like those cleaning brushes, did they come with your airbrush?
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    June 2015
Posted by OldGoat on Wednesday, January 20, 2016 9:29 AM
I have an ancient Badger 350, still good for large areas like car bodies, scenery etc.
A Badger 155 that served as my only D/A AB for 15 years.
A Badger Renegade Velocity. Until recently it's been my go-to AB for detail painting. Now no matter what I do I get splatter, lots of splatter. Hmmm new tip maybe?
A Paasche VL so old it makes my head spin, It was my mothers........
A Paasche Talon, a relatively new addition but I split the .3mm tip. Don't ask....
Brand new, still unused, Iwata Eclipse HP-CS. Airhose showed up the other day so "away we go".
I've been using the same "Bear Air" compressor for the last 8 years. No issues.
    December 2015
Posted by Dash8 on Wednesday, January 20, 2016 9:30 AM
hogfanfs
Dash,
Thanks Bruce ! I bought them on Amazon, they
are the Paasche brand, good quality brushes and a must
have. The smallest brush is outstanding for cleaning
the passage way under the cup going out to the
tip when the airbrush is stripped down.
Ontario, CANADA
    May 2013
Posted by hogfanfs on Wednesday, January 20, 2016 10:22 AM
Dash8
hogfanfs
Dash,
Thanks, Dash, I'm going to check Amazon and get me a set!
 Bruce
Posted by Tojo72 on Wednesday, January 20, 2016 11:43 AM
Iwata Eclipse HP-CS
    March 2013
Posted by patrick206 on Wednesday, January 20, 2016 3:45 PM
Paasche: VJR, V & F. Unloaded the rest of that brand.
Iwata: HP-M1
Binks Wren: A & B
Badger: 200, 200NH, 200G 200SG, 155, & 100G
Very satisfied Paasche user for decades, H, VL and Talon did the majority of my work for some time, then a few years back the routine maintenance replacement parts were poorly made, some even arrived damaged from handling.
Now I find the Badgers to be very well made, excellent quality internal parts and solidly reliable, with entirely satisfactory spray results. Pretty much my go to AB's now, old steady Freddies for me.
The old Binks Wrens go back many decades, simple, dependable and good spray results, being the single action, external mix AB's they are.
The Iwata just arrived yesterday, hose adaptor is on the way so no chance to use it yet, but in taking it apart to check it over it looks to be a superior unit.
I think my AB collection has grown to it's max now, but I have said that before, (according to herself.)
Patrick
    February 2015
Posted by Bick on Wednesday, January 20, 2016 4:57 PM
hogfanfs
<snip>
Harbor Freight sells a similar if not identical set of airbrush cleaning brushes.
http://www.harborfreight.com/5-pc-airbrush-cleaning-brushes-68155.html
cml
    March 2007
Posted by cml on Wednesday, January 20, 2016 9:52 PM
Paasche H - First airbrush. 10 years old this year, but hasn't been used for the past 7.
Badger 100LG - Primary go-to brush for me. Had it for the past 7 years, hence the reason the Paasche was shelved.
Sparmax DH-102 - nice cheap detail brush, bought out of curiosity, but has excellent value for money for fine detail work.
Iwata HP-B+ - just picked this up two days ago. Haven't had a chance to test it. I bought it for fine detail work to replace the Sparmax. I'll keep the Sparmax as a last resort back up.
Chris
    April 2008
Posted by spiralcity on Thursday, January 21, 2016 10:17 AM
I just posted the AB's I use on another thread, but what the hay, I'll give it a go once again. Stick out tongue
Paasche Talon - Paasche VL - Badger 150 - Persicion Aire Treo XF x 2
I had a Badger 175 but gave it to my brother-in-law, I plan on buying a Badger Patriot asap.
    January 2016
Posted by Liquid Magma on Sunday, January 24, 2016 6:29 PM
I have been using a Paasche VL for a long time and very happy with it. Picked up a Talon a few months ago, which does a better job with the detail, but is a little harder to clean. Like them both!
    July 2013
Posted by modelmaker66 on Monday, January 25, 2016 11:22 PM
That Badger patriot is a darn good brush. Used one for years.
