Compatability
    October 2004
Compatability
Posted by ikar01 on Tuesday, February 2, 2016 6:10 PM
I.m working on a project that will most likely have a Alclad start so I can have a metallic color for a base.  I need to find iron or something close and after that I will most likely be using enamels. to make it look like rust is starting to form on its surfaces from salt water.
I assume I need to coat the Alacad,; but should I use laquer or acryllic over the Alalad
