Testors Model Master Paint Compatible?
Posted by Anonymous on Tuesday, March 16, 2004 12:53 AM
I have an Omni 4000 double action airbrush which I'm still getting familiar with. The BIG step upBig Smile [:D]. Anyways, what type of thinner or brand (other than the airbrush thinner Testors Sells...too expensive) will mix good with Model Masters enamel paint. I Bought "paint thinner mineral spirits" at Wal-Mart and it breaks up the paint into flakes when mixed.Dead [xx(] Tried another brand at a drug store with nearly the same results. Arrrrrgggggggg! Angry [:(!] I Thought you could thin enamel paint with mineral spirits for airbrushing?
Any help, suggestions or ideas would be appreciated. At $4.00 a bottle for Testors thinnerBlack Eye [B)], there's gotta be a cheaper way.
Thanks,
Joe
Posted by MikeV on Tuesday, March 16, 2004 7:22 AM
Hi Joe.
Mineral Spirits should work fine with Model Master enamels.
It made the paint turn into flakes when you used it? That's odd.
I could see that happening possibly with the Model Master Acryl paints and mineral spirits but not the enamels. Try another brand.
I just bought some Sunnyside "Specs" paint thinner and it works pretty good.
http://www.sunnysidecorp.com/general.htm
This thinner is mineral spirits and it has a low odor.
    January 2004
Posted by MusicCity on Tuesday, March 16, 2004 7:34 AM
I agree with Mike. I don't use much enamel anymore, but I did use it for years off and on. Plain old mineral spirits always worked just fine for me.
Are you sure it's Model Masters enamel and not Model Masters acryl? The "acryl" is acrylic, and that would probably go nuts when thinned with mineral spirits.
Posted by Anonymous on Tuesday, March 16, 2004 3:28 PM
You are better off with Acrylics...all the research $$$ are going in to water based. besides you can thin with isopropyl and clean with water-iso mix...real cheap. Plus it's a lot healthier for everybody around you and your airbrush.
    July 2003
Posted by zokissima on Tuesday, March 16, 2004 3:31 PM
I'm with ausf. I've started using exclusively acrylics for airbrushing. I couldn't be happier.
Posted by Anonymous on Tuesday, March 16, 2004 10:09 PM
Some of the dirt cheap mineral spirits don't work well. Does the stuff you got feel greasy?
If you are starting out with airbrushing and don't have a huge stock of enamel paints then going acrylics might be the better choice.
Posted by Anonymous on Thursday, March 18, 2004 8:08 AM
Thanks, got some Sunnyside Spec Spirts the other day. I'll give it a try. I will probably switch to Acrylics soon since everyone's telling me they are easier to work with in an airbrush.
Joe
Posted by ajlafleche on Thursday, March 18, 2004 10:04 AM
I thin my MM enamels with buck a gallon thinner from the hardware store. Never had a problem. Sounds like you inadvertantly had acrylic paint.
    May 2003
Posted by styrene on Thursday, March 18, 2004 11:42 AM
Testors airbrush thinner is also a mineral spirits-based thinner with a higher volatility.
Since mineral spirits are typically petroleum solvent-based (long-chain aliphatic hydrocarbons), there is going to be a little bit of an oily, lubricant-type feel to it.
Gip Winecoff
Posted by MikeV on Thursday, March 18, 2004 7:07 PM
Your posts are always informative Gip. Thanks for enlightening those of us who are kind of clueless as to these things. Big Smile [:D]Wink [;)]
PS Is your email working? I have not heard back from you in a few days. Confused [%-)]
Posted by MikeV on Thursday, March 18, 2004 7:11 PM
Joe,
Sunnyside also makes a product called, "t.r.p.s" (Turpentine Replacement Paint Solvent) that Greg Williams, I believe, said worked even better than mineral spirits. Maybe Greg can let us know about that again. Greg?
Posted by Anonymous on Wednesday, April 14, 2004 9:04 PM
Hey, Laquer thinner works great for cleaning enamels. Big Smile [:D]
Posted by Anonymous on Thursday, April 15, 2004 6:36 PM
QUOTE: I Bought "paint thinner mineral spirits" at Wal-Mart and it breaks up the paint into flakes when mixed.
Hey Joe , was it the "Klean-Strip" thinner for 1.98?
