Air Pressure Regulator vs. Air Flow Regulator
    February 2009
Posted by maxdtex on Wednesday, March 2, 2016 12:11 PM
I want to replace the air pressure regulator on my Paasche D3000R with a digital gauge so it will be easier to read. All the digital models say "air flow regulator." Is the air flow regulator the same as the air pressure regulator?
    February 2014
Posted by CN Spots on Thursday, March 3, 2016 8:31 AM
A flow regulator is like the petcock valve (or faucet) on your garden hose.  It controls the flow of liqiud/air through a device.  Turn it a little bit and only small amount comes through but it will continue to flow through until the pressure equalizes on both sides of the valve.  That's why you get a blast of water from a garden nozzle when you first squeeze the handel then it dwindles down.  The same will happen to your airbrush.
A pressure regulator, well, regulates the pressure that the air/liquid is released at. This is what you want on an airbrush.
    February 2009
Posted by maxdtex on Thursday, March 3, 2016 9:42 PM
Thanks
