Hi all
Just starting on modelling and i need some help understanding when how and why using coats
When do you use matt coats? When do you use gloss coats? what are the best brands to use?
As you can see im a bit lost...:) anyone can give me an overview of this subjet?
Thanks a lot!!!!!!
On the Bench: Revell 1:48 B17 Flying Fortress
One example is the application of decals. Many folks use flat/matt paint if the final finish on the model should be matt. But decals do not work well over flat paint. So you need to apply a gloss clearcoat, at least in the areas where decals go. Then, to get the final flat finish you need to spray with a flat/matt clearcoat.
Sometimes you cannot get the color you need in the appropriate sheen. So you can change the sheen by using the appropriate clearcoat. Getting a really good shine with gloss paints can be difficult- gloss clearcoat can change a sort-of-gloss to a really glossy sheen,
Hi Don
Thanks for your answer!! a bit more clear now.
I have read also that applying a gloss clearcoat helps you when wathering your model. Do you know if you will get the same results with a flat/matt clear coat?
Spray the whole kit in glosscoat and let dry prior to decalling. Once decals are on, spray a coat of flat/matt.
brosallman Hi Don Thanks for your answer!! a bit more clear now. I have read also that applying a gloss clearcoat helps you when wathering your model. Do you know if you will get the same results with a flat/matt clear coat?
Yes. A lacquer clearcoat will protect acrylic paint surfaces from solvents used in many washes.
