masters airbrush
    July 2013
masters airbrush
Posted by steve5 on Thursday, March 10, 2016 4:24 PM
has anyone had anything to do with masters airbrushes , what i'm looking at say's american but the price scare's me , they seem too cheap , probably for a reason . any help will be appreciated .
steve5
    June 2010
Posted by 5-high on Thursday, March 10, 2016 5:31 PM
Well Steve 5 ..
I payed $40. For myn . What type is it ??..
Is it a gravity feed or syphon type.
There not bad of a airbrush for the price ..I think it's a Chinese knock off. .looks the same as master. But it has a plastic rear instead of metal. . P.s myn is a gravity ab
5-high
    March 2013
Posted by patrick206 on Thursday, March 10, 2016 5:44 PM
Steve
I've not used one, but have read and heard they are generally considered "knock off" products, possibly made as copies of other brands, likely Asian.
Tales have been both good and bad, kind of pay your money and take your chance. Some folks have had great results, others say they're not worth taking home. Case by case I guess.
A good website to check out for detailed info is: Don's Airbrush. Plenty of good information regarding  types, brands and quality. That should give you enough to go on.
For what it's worth, plenty of good quality, name brand airbrushes available through the dealers, I use mostly Badger, some Paasche and Iwata. Discount sale prices available at businesses like Chicago Airbrush, TCP Global, Coast Airbrush and Webair.
Patrick
    July 2013
Posted by modelmaker66 on Friday, March 11, 2016 12:32 AM
like patrick said, mixed responses. I use an Iwata NEO and it is the cats meow and onlt about $40.00 from hobby lobby with the 40% off coupon. It is made for Iwata but has never given me trouble and does a great job. Just a suggestion.
    August 2005
Posted by Phil_H on Friday, March 11, 2016 2:21 AM
steve5
Nup, they're made in China. Visually, they resemble those of "name brand" manufacturers, but the mechanisms are a little different.
Check these out, I believe Fengda OEM's for some of the low-cost companies. http://www.airbrush-fengda.co.uk/double-action-airbrush-pistols.html
    December 2015
Posted by templar1099 on Friday, March 11, 2016 6:17 AM
I've got 3 of them, E91,G22,and S68 that I bought as a package along with a Master compressor for less than 200.00 when I started. Eventually after tweaking all 3 give good service, each set up for specific tasks. They are Chinese knockoffs and there are probably more negative comments than positive but I must have lucked out. While you can buy tune-up kits for them I don't believe anyone will service them. Good luck.
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
    January 2014
Posted by jelliott523 on Saturday, March 12, 2016 6:36 PM
Ive got the G22 and to be totally honest, its not that bad. It was my first ever airbrush and didnt want to spend a lot of money learning how to use one and then be disappointed if I couldnt get the hang of it. I've since bought a couple of newer, higher dollar brushes since. My second brush I purchased was a Paasche Talon with .38 needle. I really like the way this brush works, and cleaning is much easier. The Master is okay, but cleaning can be a bit tricky putting it all back together. With the Talon I can get a lot better fine lines and detail and the pressure is easier to control. I've also purchased a Badger Krome; however, I have not received it yet so I cannot comment on its performance. All-in-all, if you are just learning, the Master isnt a bad way to go, but I can guarantee, you'll eventually want a better brush once you get the hang of how they work.
    November 2008
Posted by plasticjunkie on Monday, March 14, 2016 7:14 PM
You won't go wrong with Badger. They last for ever!
 GIFMaker.org_jy_Ayj_O
