My road to airbrushing
    May 2014
Posted by celowbe on Wednesday, April 6, 2016 3:35 AM
So thought I'd make a thread instead of making multiples in the near future.
My setup consists of a Tamiya Sprayworks HG airbrush II mated with a  Sparmax 100Hp compressor.
Hopefully you guys can help me on my little journey to scalemodel painting and help answer some of the problems i come across. TIA
    May 2014
Posted by celowbe on Wednesday, April 6, 2016 3:36 AM
So first thing I've come across is orange peel on my primer coats. Ive done 3 primer coats and have noticed its got orange peels.
Should I start the color coats now or lightly sand the orange peel with 2000 grit paper then color paint?
    December 2015
Posted by templar1099 on Wednesday, April 6, 2016 4:47 AM
I'm still pretty new to all this but I'd address the orange peel. Weather can affect it but also distance from brush to subject can cause it and also too high a pressure. I haven't been satisfied when I try sanding imperfections it always seems to leave a " disturbance"in the coat.
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
    May 2014
Posted by celowbe on Thursday, April 7, 2016 1:03 AM
templar1099
Yup that's right. The paint dried up before it got to the model. Knew it was too humid.
I'll give it a go with 2000 grit and do trial and error. Lucky it's a test shell
    August 2015
Posted by crown r n7 on Thursday, April 7, 2016 11:36 AM
you should lightly sand the primer coat so you have a smooth canvas to work with
 Nick.
    May 2014
Posted by celowbe on Friday, April 8, 2016 4:14 AM
So today lightly sanded the primer and started airbrushing the color. First coat was fine. Then i started getting these white marks. Im using mr color gun metal lacquer diluted 1:1 thinner. What is this white residue? Sorry no pic. Will upload later on.
    December 2015
Posted by templar1099 on Friday, April 8, 2016 12:57 PM
As I stated ;still relatively new to this. Is it color or material,this residue ? I would guess it's the lacquer. Post this question in Painting and Airbrushing, I guarantee that you'll get the answer.
    March 2013
Posted by patrick206 on Friday, April 8, 2016 2:30 PM
Celowbe -
Without photos it's hard to tell what you're seeing, but I'll take a stab. First, I start at a thinning ratio of 3:1, paint to thinner, then make adjustments as needed following test spray. It's not very often that I thin 1:1, but sometimes I do if required.
I have never used Mr.Color metal lacquer, is it possible that like Alclad it's intended to be used undiluted?
Once I'm satisfied with my thinning ratio following test spray results, I set my pressure at whatever works best, usually 15-20psi, then holding the AB about 3-4 inches away from the model I spray an even, glossy coat, but no more than required to make the pass lay down smoothly. To continue passes past that point invites runs, (sags,) that resemble teardrops.
If the AB is held too far away, the paint particles dry before reaching the surface, that pebbly finish can only be fixed by sanding smooth, then repainting. I generally apply two or three coats, about 5-15 minutes apart, depending on the paint and air temp.
As to white spots appearing, the only things I can think of are partially dried residue in the AB being spattered on the surface, or possibly a reaction between paint and thinning agent.
I hope you get this sorted quickly, please let us know how you do.
Patrick
    August 2005
Posted by Phil_H on Friday, April 8, 2016 7:55 PM
celowbe
Please confirm the paint you're using. As far as I'm aware, there isn't a gunmetal in the Mr Color range. The nearest I know of is (c)28 Steel.
Depending on humidity at the time, the white marks you're referring to may be the result of condensation in your air hose being deposited on the painted surface.
