Clear cote gone cloudy
    December 2014
Posted by rsm.gbg on Sunday, April 10, 2016 2:04 AM
I used Humbrol Satin Clear on my Corsair F4U-1D.I guess it was to humid or cold because now it looks like I spilt milk on it.
How do I best get rid of the cloudy stuff so I can redo?
Should I sand it down or is there something to "clean" it with that works?
I've used Tamiya Acrylic paint under.
    May 2013
Posted by Snibs on Sunday, April 10, 2016 2:16 AM
I use the Humbrol gloss clear and it's great, then I tried the matt clear and it was white cloudy in the bottle and it tested the same, spilt milk cloudy, I'm guessing the satin is the same or maybe it was humid as you say, was it cloudy in the bottle?
As for fixing, go over it with Clear gloss and it should be ok (not in humid conditions).
Quite a few complaints about the Humbrol Matt clear on the web.
Mick.
Some stuff that might be interesting.
https://sites.google.com/view/airbrush-and-modeling/home
On The Bench.
Tiger 1 and Tooheys.
    December 2014
Posted by rsm.gbg on Sunday, April 10, 2016 2:32 AM
So just a cote of Gloss clear should magically just make the milky stuff vanish?
    May 2013
Posted by Snibs on Sunday, April 10, 2016 4:26 AM
if its cloudy from humidity then yes but if there was to much matt agent in the matt clear then who knows, prob not, but cant hurt to try.
Was the bottle cloudy?
On The Bench.
    December 2014
Posted by rsm.gbg on Sunday, April 10, 2016 5:04 AM
Its Satin not Matt and yes very cloudy in the bottle.
I've done some investigation on my cheap air-pressure tank from Aldi.
It doesnt have any moisture separator, that might be the problem.
    May 2013
Posted by Snibs on Sunday, April 10, 2016 5:26 AM
Moisture could be a problem but not in this case I don't think, it's the satin clear, I and many others have tried to get some response from Humbrol but as normal not a word. The gloss has been out for ages but the satin and matt are new.
Can't hurt to try gloss clear and see if it helps but I'm not confident if it will help now with faulty product. Let me know how it go's.
Mick.
On The Bench.
    May 2013
Posted by Snibs on Sunday, April 10, 2016 5:33 AM
Forgot to mention, if your using a air tank you probably wont have moisture problems anyway.
Air cools in the tank and thats why you drain them, however I have never seen water in my tank or water trap ever. It's one of these but unbadged.
http://www.amazon.com/dp/B001738DXU/ref=twister_B00R6TE6TE?_encoding=UTF8&psc=1
Mick.
On The Bench.
    December 2015
Posted by templar1099 on Sunday, April 10, 2016 5:40 AM
I used a mix of Future and Tamiya clear flat on a kit and way over did it on the Tamiya, it came out not only cloudy but white. A coat of straight Future cleared it up.
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
    December 2014
Posted by rsm.gbg on Sunday, April 10, 2016 5:54 AM
Maybe my cote was to thick?
After reading on Humbrol it says to spray very thinly.
I wish we could get Future in Australia.
The only option I found was very expensive, like $40 a bottle + shipping
    May 2013
Posted by Snibs on Sunday, April 10, 2016 6:13 AM
No it's the satin and matt by Humbrol, the gloss clear is great and very much like future from what I can tell, as close as we get here in oz.
On The Bench.
    May 2013
Posted by Greg on Sunday, April 10, 2016 9:04 AM
rsm.gbg
Possibly, according to my real life experience of doing the same (not with Humbrol though)
    December 2015
Posted by templar1099 on Sunday, April 10, 2016 10:49 AM
I think the moral of the story is to use a coat of whatever clear gloss you use to clear the cloudiness.
    May 2013
Posted by Greg on Sunday, April 10, 2016 11:02 AM
templar1099
Agreed. (and yes, it does work)
Posted by Don Stauffer on Sunday, April 10, 2016 11:25 AM
Glosscoat and Dullcoat can fog with just ambient humidity-  don't need water from compressor.  Both are lacquers.  The fast evaporation from lacquers cools the surface below dewpoint when humidity is high.  Water condenses on surface and is rough, causing the white fog. In fact any lacquer can do this, not just GC and DC.  Learned about this when learning to paint cars with lacquer. It is a problem.
Oh, BTW, Testors did bring out enamel gloss coat, but they seem to have gone back to lacquers (thank goodness).
