First off iSteve, don't you be name calling yourself over Testors poor choice of paint nomenclature! (MM Grey (or Gray) Primer). Not one of their finest moments, IMO.
So good on you for not mixing the Alclad with anything.
I'd be remiss in not asking what you thinned the Tamiya with. It should hang onto the Alclad well. (If shoulds and coulds....etc, etc).
One more thing, you mentioned you usually use Tamiya masking tape. "Usually" probably doesn't belong in that sentence. And I wonder, do you de-tack the Tamiya prior to using it? As forgiving as Tamiya is, I still de-tack it. Do you?
Just so you don't feel alone, my first acrylic paint job went like this: MM Grey Primer (you get to laugh at me, it's ok), followed by MM Acryl, and followed then by blue painters tape. Not a happy ending.
