Is Future compatible to be mixed with Tamiya acrylic flat paint?
I mix it with their flat clear for finishing, don't know what difference pigments would make.
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
plasticjunkie Is Future compatible to be mixed with Tamiya acrylic flat paint?
Yes. I have done it before to turn a flat color gloss to eliminate the need for a gloss coat and speed up the finishing process on a Weekend Madness GB here.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
- Plankton
LSM
Thanks stik.
Do you also use thinner when mixing Future with acrylic?
maxdtex Do you also use thinner when mixing Future with acrylic?
I used Tamiya X20A acrylic thinner with the Tamiya paint and it worked just fine. The more Future you add the glossier it looks.
I have thinned Future with alcohol or Windex when spraying thru my AB. I get a smoother spray texture when I thin it.
I did, but not as much, IIRC. It has been a few years.
