needle valve adjustment
    March 2016
Posted by ardvark002 on Friday, June 17, 2016 6:37 PM
Hi, I know I should totally have figured this out by now, but Ihave a question. Where in respect to a siphon feed gun, does the oriface go? Up , down, or sideways to get best paint flow? I think I've figured it out, but any help would be great. I have a badger 350.  thx  aardvark
Posted by Don Stauffer on Saturday, June 18, 2016 10:02 AM
Not sure exactly what you mean, but with suction feed, if the bottle is attached properly, the bottle is at the bottom, sitting close to vertical, with the cap/feed at the top.
    October 2008
Posted by Don Wheeler on Saturday, June 18, 2016 11:10 AM
By orifice, I think you mean the hole in the side of the needle that the paint flows through on the 350.  I doubt whether it makes any difference.  If it did, Badger would have probably keyed it.  But, why don't you do some experiments and let us know what you find?  The Paasche H is a similar design and it isn't keyed either.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    March 2013
Posted by patrick206 on Saturday, June 18, 2016 5:40 PM
Don Wheeler
Don
As Don suggests, if you are referring to the machined port on the side of the needle, I can't see that it would make any difference what the orientation of the needle is. Siphoning action will simply pull the paint through the needle, then it's sprayed in the airstream.
Once assembled and the needle is tightend, the threads will determine the orientation of the needles position. Shimming the needle base I guess could change the rotational position, but then it would change the needle tip position relative to the aircap and the airstream.
Patrick
    March 2013
Posted by patrick206 on Sunday, June 19, 2016 2:13 PM
patrick206
Don Wheeler
Don
Patrick
Disregard above, I was thinking of the Binks Wren, the needle threads do fix the needle into the body. The Badger 350 and Paasche H needles are fixed into the body by the little screw, and can be rotated as desired.
Sorry.
Patrick
