If bleeding under the edges of the tape is a problem, you can seal the edges.
When you are done with the lighter color, put one more thin coat down. Concentrate on the tape edge areas, just blend in so you do not need to do big open areas. Any bleeds of the lighter color will be the same color as what is there, so it will not show. This is a good idea any time you are masking a multi-color finish.
