Airbrushing canned Tamiya Fine Surface Primer (L)?
    August 2016
Posted by scaler on Friday, October 7, 2016 1:45 PM
I plan to airbrush decanted Tamiya Fine Surface Primer (gray), and I understand it's lacquer-based, same as their Liquid Surface Primer, is that correct? If so, I plan to use laquer thinner for thinning and cleanup. In other words, should this primer be treated any different than LSP in that regard?
Another question: can this decanted primer be stored in airtight plastic jars or will I need to use glass ones?
Thank you! Smile
Some think this is actually fun!
    April 2009
Posted by Cadet Chuck on Friday, October 7, 2016 6:51 PM
Why do this?  I have found Tamiya primer works just fine, using the spray can.  Just be gentle and spray a light coat.
    August 2016
Posted by scaler on Sunday, October 9, 2016 10:28 AM
Cadet Chuck
Why do this?
Well, that's a question that has been asked and answered many times before. In short -- to have better control of what you are doing. Spraying from a can would be great for broad indiscriminate coats, also when ventilation is not an issue. However, when you're at your desk or a hobby spray booth, working on something small -- it is a different story.
    July 2014
Posted by Bakster on Sunday, October 9, 2016 11:07 PM
Scaler--I have decanted TFSP as well, and I did use lacquer thinner to cut it. It worked great, and it is my go-to for primer.
I am not an authority on TFSP, but my understanding is that it is lacquer based. I used a glass jar to store it only because I was not sure if any of my plastic containers would hold up to it.
I have just one other tip. Remember to let it gas out after decanting. It is a real boiling stew at first. Some say that at all those bubbles can cause a person trouble when spraying. So I let it gas out for a few hours. I had no issues by following this process.
    August 2005
Posted by Phil_H on Monday, October 10, 2016 12:27 AM
Why not just airbrush the bottled Liquid Surface Primer?
    August 2016
Posted by scaler on Monday, October 10, 2016 10:00 AM
Bakster: Thank you, I did just that yesterday. Used a glass baby food jar, those have very good lids. Hope that the coating on the underside of those lids won't interact with the liquid. Haven't tried cutting or spraying it yet, as I was also fine tuning my compressor.
I didn't decant a lot, so I put the jar into warm water to let the propellant to boil off. Worked like a charm. Smile
    August 2016
Posted by scaler on Monday, October 10, 2016 10:05 AM
Phil_H: One reason is that Tamiya does not sell its fine gray primer in regular bottles. And some say that it's thinner than LSP, providing smoother finish. Another reason is the cost: my LHS sells these rattle cans for under $7/ea.
    July 2014
Posted by Bakster on Monday, October 10, 2016 10:47 AM
Scaler: that is great to hear. Yeah that is the beauty of decanting. You can decant what you need and leave the rest for almost indefinitely. I think that in the long-run it is a good value, like what you alluded to. There is a good amount of paint in those little cans. BTW... I used an airbrush jar to store the decanted paint. For bigger jobs, your baby food jars idea should work awesome...
    December 2009
Posted by Tucohoward on Tuesday, October 11, 2016 1:52 PM
scaler
Actually they do, item #87075. Excellent primer for sure and at $5 for 40ml it's got to be a much better value than decanting spray cans of the same thing.
Jay
The Mighty Mo says no.
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, October 12, 2016 11:07 AM
Or get this stuff:
http://www.squadron.com/Badger-Gray-Primer-2-oz-BGSNR202-p/bgsnr202.htm
My go-to primer instead of decanting....
    August 2016
Posted by scaler on Wednesday, October 12, 2016 6:57 PM
Tucohoward
$5 for 40 ml vs. $7 for 180 ml? Something's wrong with your math, I think. Plus, LSP is not the same as "fine" primer in a can, is it?
    August 2016
Posted by scaler on Wednesday, October 12, 2016 6:58 PM
Or get this stuff:
Thanks, I will consider it. Smile
    August 2005
Posted by Phil_H on Wednesday, October 12, 2016 7:03 PM
scaler
Once you thin it, it goes a lot further. Also, remember that the 180ml in the spray can includes the propellant. The 40ml in the jar is all primer.
When thinned for airbrushing, LSP goes on silky smooth.
    December 2009
Posted by Tucohoward on Thursday, October 13, 2016 5:38 PM
scaler
Not an apples to apples comparison. Spray paint is always more expensive than bottled paint per square foot. That 40ml bottle will give me what I would get from several 180ml spray cans. Most of the contents of the spray can is not paint. No free lunches.Smile
Jay
