semi gloss
    March 2016
semi gloss
Posted by ardvark002 on Monday, November 7, 2016 6:44 PM
Hi all, Can anyone inform me where I can get  clear semi-gloss airbrushable paint?  THX Aardvark
    July 2004
Posted by stikpusher on Monday, November 7, 2016 6:55 PM
Humbrol makes a clear satin coat. Just add thinner.
I do not know of any pre thinned semi gloss, flat or gloss top coats out there.
you can mix your own using Future and Tamiya flat base...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    March 2016
Posted by ardvark002 on Monday, November 7, 2016 7:07 PM
THXS , Aardvark
    March 2010
Posted by Nathan T on Monday, November 7, 2016 7:24 PM
Tamiya,Gunze Mr. color, Alclad, Ammo, AK, all make gloss, semi gloss, and flat clears. Some, such as Alclad, are pre thinned.
Posted by Don Stauffer on Tuesday, November 8, 2016 9:26 AM
I use Testors enamel, and the only semi-matts they make are Black Chrome, which is a satin black, and a new satin clearcoat.
However, airbrush technique can create semi-gloss satin appearance.  If a gloss paint is laid down very dry/thin, it will not develop a high gloss.  If flat paint is put down with a very wet/thick coat it will have more of a lustre than when done as multiple thin coats.
Also, a flat finish can often be burnished with a very soft material such as Kleenex (but it does leave small bits behind which need to be cleaned off) or a very soft, clean rag.
Also, leather can be simulated by burnishing a flat paint with your finger- the oil from your skin makes a semi-matt lustre that is much like leather.
Before Testors came out with its semi-matt clearcoat, I used hardware store clear polyurethane thinned to airbrush consistancy.  Several brands of polyurethane offer a semi-matt/satin clear.
