Regarding spray booths, it's always best to duct to the outside with a squirrel cage motor, which is a type that gets keeps the motor out of the airstream. Computer fans, window fans, etc. unless they are listed explosion proof can be a source of ignition. If you are spraying from a rattle can, you are using a paint that is definitely flammable.
I had a friend who routinely cleaned clay off his shop floor with acetone. One day, the door to his basement was left open and the heavier than air fumes crept down the stairs to the water heater pilot and flashed right up to his face, burning off his eyerows and front of his hair. He was wildly lucky he didn't have a bigger disaster than that. The solvents in most rattle cans are more volatile than acetone.
The other thing with filtered booths: an organic vapor respirator cartridge is only good for 8 hrs of usage, 2 weeks exposure to air while not in use. The active ingredient is charcoal and absorbs the solvents to a point where it can't any longer. Basically, it's useless for fumes in a spray booth and that's even if the booth's filter is an OV or just a particle filter. It might catch paint particles, but that's not the complete issue with paint, unless you are using true acrylics (not ether based like Tamiya).
But of course, the original question is rattle cans, so the short answer is no. Atomizing a flammable material is what a carburator does, add an ignition source to that and well,you know...
If you think this is a case of over reacting, check on the spray booth you're interested in and see if they say it's okay for flammable materials. It may be, but I doubt it unless you're paying for it.
The upside is, with a few materials like plexi or sheetmetal, some duct work and a Dayton blower, you can build a booth for the same or less than any store bought unit that will completely out perform any of them and be much safer to boot.
